engine mount confusion!
Old Mar 5, 2009 | 08:07 PM
cossie*mad!'s Avatar
cossie*mad!
Fucked On Race Day!!
Default engine mount confusion!
can i use the actual mounts (not the arms/supports that bolt to the block) from a 4wd for 3dr?: doing a conversion and have bought new mount arms, but cant source 2wd standard mounts. can i use the 4wd ones? is there any difference?
Old Mar 6, 2009 | 06:30 AM
2wd and 4wd totally different they way they secure to the crossmember, 2wd has one through bolt going through crossmember, 4wd has two bolts 180 degrees apart bolting through.
Old Mar 6, 2009 | 08:38 AM
olek's Avatar
olek
2wd standard mounts are the same as the standard ohc-sierra has, shouldn't be that hard to find?
Old Mar 6, 2009 | 10:04 AM
Still available from ford, 4wd/2wd available in poly too.
SmudgerByName
52
Jul 28, 2016 06:14 PM
dal3door
Aug 13, 2015 06:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
