Cossie plug leads
Chasing Radders
Originally Posted by wimwerf
but its never proofed the originals are better.
strange all the wrc cossies driving with blue 909 leads
_________________
_________________
in fact about the only commonality between them is the colour.
Chasing Radders
_________________
_________________
_________________
_________________
_________________
_________________
My mates car has the blue ones and it seems to run fine.
My car is a smsll turbo whitch i converted to a large turbo i had to buy special long leads to fit my cam cover. They looked like the motorsport leads.
Got a new engine with the normal type head/rocker cover so i need new leads just wana get the best ones.
i have known the magnacore to break down but never heard of the 909 s to ????
I know where the lead make up came from, and which back door it came out of Ford from..............
For the record, I've run with 909 leads on my car for 5 years without a single problem.
Originally Posted by Stu @ M Developments
Ive never had any problems with any 909's ive sold so far.
What i will say for either set though, is to convert the system to the catalyst cap and use the 1 piece leads.
Oh ,and I use these,msd, american ignition specialist jobbies ,nice!
puddy
my mate put a set on his car. two months later i went with him to karls to get it chipped. after karl had installed the chip and done his initial set up he took the car out , on his return he reported a missfire and suspected the leads. we doubted this as the leads where only 2 months old however on investigation it was found all 4 leads had extensive corrosion where they fit into the dizzy cap. so in answer to the original question beru leads are better by far.
impreza wrx sti version 8
4wd are same as 2wd Gus
Only the calalyst equipped models had the revised cap
ignition system!
cheers ,puddy
ignition system!
cheers ,puddy
the Originals are £50.00 each lead
how much are the motorsport leads around £80.00 a set if i m right
where do you buy them from as ford motorsport are no longer trading
wheelwizardrefurbs
24-09-2015 08:35 PM
