Water pump or thermostat? Wierd one.
Ok this is on my Primastar (trafic, vivaro equivelant) Pulled over the other day and noticed my fans had cut in, but temp guage was reading normal. then checked header tank and when i took the cap off it boiled over.
Weird thing is temp guage always reads normal and all hoses get hot but van would seem is definately getting too hot. Thought was water pump was not circulating properly, any help is appreciated. Had enought of this van.
I was hoping you'd see the post been a huge help in the past. No dosent boil over if left, It doesnt have air-con and temp guage always stays in middle, has once or twice spiked though like gone high then imediately leveled out like there was a blockage or sumats.
Oh yeah the only thing that makes me think its overheating is that the fans come on even when I havent been sat in trafic. They just come on after ive been driving for a while then cut out say 30 seconds after i turn the engine off.
temp gauge should of shown it!do ya heaters get hot?have you checked the hoses and rad to make sure the circulation is good?you could always run it up get the fans in wait till they cut out then slowly undo the cap,it should not boil over at that stage!i presume you have no nasty noises from the cambelt area?i see you are doing ya belt!always good practise to check ya pump for play and to check the bearing by simply spinning t and see how it feels!(much the same way u would check the wheel bearing!)
Sounds to me like it is doing what it should.
All cooling systems get hotter when the engine is turned off, as water stops circulating so it gets hotter, enough to put the fan on, which cools it down enough for them to go off.
timsrs
22
24-09-2015 08:14 PM
