Car Mapped & Ready To Come Home
hi guys my car is finished and will be coming back to me on thursday. It went to mtech to have megasquirt management installed and the be mapped and rolling roaded. All is now done and he said the engine is solid and very reliable. It only made 160bhp at 11psi as the actuator needs replacing, but made 220lbft of torque, and he said it pulls like a train boosting fine at 18psi but then its drops to 11psi due to the actuator, so once that is sorted i should see and easy 200bhp i hope. Spec is
2.1 ZVH EFI Engine
Calibra Turbo Mahle Pistons
Standard Zetec Rods and crank
Standard T3 & Actuator
Standard Clutch
Standard Gearbox
Motorsport Fuel Pump
Beige 701 Injectors
All the standards are to be upgraded shortly
2.1 ZVH EFI Engine
Standard Clutch
Standard Gearbox
Beige 701 Injectors
YES I KNOW I CANT SPELL
2.1 ZVH EFI Engine
Standard Clutch
Standard Gearbox
Beige 701 Injectors
2.1 ZVH EFI Engine
Standard Clutch
Standard Gearbox
Beige 701 Injectors
They should replace the actuator (with your permission) before mapping.
It will need re mapping if you replace it after they have mapped it.
Sending it home like that is their first mistake!
Seems ike they have been up setting other RS turbo owners.
http://www.turbosport.co.uk/showthread.php?t=140490
but tthey have mapped you car with a duff actuator so that as soon as you fit a new actuator the map is going to be wrong and you will have to get it remapped!!!
Doesn't sound very professional to me
they mapped it to 18psi with boost controller fitted so it is ready to run a different actuator, i,ve had 2 rs turbos and both times i changed the actuator i never had to get the car remapped, and nothing went wrong.
i bort an ecu from ebay (megasquirt) and it dident work
so i sent it to them and they said i was one of there ecus that they supplyed to the privious owner. the repaired it free of charge and sent it back to me all i hade to cover was the postage lol they could have kept there mouth shut and made a quick buck as i would have been none the wiser ive spoke to a bloke down there he seens akool guy from my (little)expirence with them then seem ok.
dont like the sound of mapping a car with a doddy actuator tho??
Garage19 is right...you car has been mapped to 18psi your right but then it tails off to 11psi at high revs so your map will be a mile out at high revs...it will only be right till the boost starts to drop.......
You'll melt it....
Send them an actuator if needs be and get it mapped properly at full boost before it comes back...then if anything goes wrong you can take it back safe in the knowledge that it won't be your fault.
2.1 ZVH EFI Engine
Standard Clutch
Standard Gearbox
Beige 701 Injectors
2.1 ZVH EFI Engine
Standard Clutch
Standard Gearbox
Beige 701 Injectors
As said; as soon as you put a new actuator on it, the custom map will be wrong.
take people's advise off here; otherwise you will risk blowing your motor up
Should that spec not run that much power at a lot less boost......you can get that power out of a 1.6 cvh at that boost....
I know its your money mate but the amount of money you must have spent on that engine i would not be trusting that map.......
![Rolling Eyes](https://passionford.com/forum/images/smilies/icon_rolleyes.gif)
thanks for all ur replies, i understand what ur saying i cant afford to keep the car thier any longer thats why i didnt get the actuator done. I will wait and just run it how it is for a few months coz i got a lot to uprate anyway. Once i have done the actuator put a bigger intercooler on and an uprated clutch and better gearbox i will get it sent back down and remapped. I didnt want them to push it too hard coz of the standard clutch i wanted to be able to drive it and not worry about the clutch slipping.
Did the Dyno have cooling fans? -- I can't see any in pics ?
yeah mate they had the fans but said it kept cool anyway and yes it is standard infact everything is standard bar the bottom end.
I've dabled a fair bit with megasquirt. Just out of ineterst, what did they charge you to supply, fit and map the ecu?
I agree, a 2.1 zvh should make more power than that even on a stock head. If i were you my next step would be to swap the RST T3 for a cossie one and check your cam and followers.
The problem is you shouldn't have been hearing the advice about the actuator on here. It should have been coming from Mtech.
Colossal Pervert
I think everyone is assuming that the thread starter is accurately repeating/understanding what he was told by the supplier. This may or not be the case, but it's probably best not to go off on a mission about them!
Did they fit the ecu? Are you running a coil pack and 36-1 tooth crank speed sensor?
Ł500 is what i would call proper money for mapping a car. I would expect a top notch job for that. Let us know how the car drives/starts when you get it back. Starts first time from cold and hot? Drives smoothly around town, on and of the throttle?
just spoke to mtech they are bringin it back on friday, i questioned him about a few things and he said it would be best to leave it thier and let them fit the acutator but i told him i cant afford it and will get it done in a few months. He also said car starts and runs fine, he said normally when u fit aftermarket management they can struggle to start and run lumpy on idle be mine runs great.
the car is now back and i,m happy with it but thier are u few things i,m not too sure on, it doesnt idle very well when cold sitting at 500rpm but mtech said thats what happens when u fit aftermarket management, But the idle speed control valve is not even connected. Cap still blows off but when it does car runs shit which is a good sign. Also its hesitant on acceleration, it seems to struggle when u floor it but then kicks u back in ur seat, cant really figure that one out. It is quick thou which i,m happy with
Ban[B][/B]ned
Take Garage 19 and the other lads advice. The problems you've described are what he told you to look out for. Remember, he isn't saying this because he needs your money as he isn't getting any off of you. He's advising because he doesn't want you to get conned or robbed. If this was mapped by someone like NMS, MSD, APT, ETC - I am sure it would idle fine and drive fine. Chip said a while ago, anyone can map a car to go quick, but getting it to drive cold, off boost etc is the difficuilt part.
Benni.
Benni.
"it doesnt idle very well when cold sitting at 500rpm but mtech said thats what happens when u fit aftermarket management"
If they said that then it pretty much sums up why you shouldn't use them.
What is the cap blowing off that you refer to???? Why is the car running shit a good sign???
What you have described is poor mapping of warmup enrichments, poor setting/mapping of idle speed and poor mapping of transient fuelling.
Take it back and tell them that for Ł500 you expect these things to be right.
Mate, I paid NMS a figure not that diff to what you've paid to map my cossie, and its PERFECT. I started it for the first time since August 2 weeks ago, and it still fired and idled perfectly. You should accept nothing less.
An actuator is Ł120 or so - I know how it feels when you've done all your cash on the car and it needs more, as I got mine back from mapping and the fucking actuator rod snapped a week later!! Beg, borrow or steal that money get one and get them to map it properly, or all you've done is wasted that Ł500 on mapping which will just need doing again anyway.
i'm no expart on mapping, far from it in fact
but i do have experience in a motorsport back ground
and all our cars ran aftermarket management
all came with a base map that made the car run pretty much the way you describe
but after they had been mapped on track(by somebody else on the team not me
they always came back with much more power, torque etc
and ran better from cold/light throttle etc,
sounds to me like its just running a slightly mod'd base map
than the full live map that you paid for
i wouldn't be happy at all for that money
as we used megasquirt a couple of times and i can garauntee you that if
mapped correctly they run fine when cold etc,
i think they just cant map well enough to do this
thats why they're aftermarket ecu's never run right
this is just my opinion, i have never dealt with this company or this car
so no offence intended to anybody, but sounds fishy to me
![Red Faced](https://passionford.com/forum/images/smilies/icon_redface.gif)
As everyone's sayin i wouldn't be impressed if i'd shelled out that money.....thought they had told you on the phone that it ran lovely and started fine etc, you should have test drove the car when they brought it back and sent it back with them to properly, easy to say i know but you're obviously not happy.
basically it sounds like you been done for Ł500 for a live map which is shit - get it sorted or demand a refund. A live map should be perfect
why people like this go to micky mouse tuners is beyond me
Doesn't sound like you got your money's worth mate! I live in Hong Kong and don't have anyone here to live map my Escos, but recently I've upgraded to wasted spark, coilpack, ALS and Evochip from Stu at MSD. Due to differences in fuel, atmospheric pressures etc, the car had part throttle / transient load issues which I discussed with Stu. With the help of Stu and my LM-1 lambda meter, we were able to isolate the fueling issues and he sent over a revised map chip for me to try!
What a difference!!! Although not as good as having Stu here to live map, but must be 99% perfect!!! Idles smooth, drives well on part throttle and absolutely amazing from 2,500RPM upwards at WOT!!! Sounds like what Stu can do remotely from the other side of the world, your guys can't do with a live map and aftermarket management! And I spent nothing close to that you paid!!!
Good luck mate, hope you get it sorted soon!
also has anyone heard of cosworth orane or tangerine injectors 330cc, well he put these in instead said the beiges werent good enough.
Colossal Pervert
You can't really go by colour, but no, no Cosworth injectors were ever 'orange'. They'll most likely be from something else. Either way, 330cc/min is more than enough for your spec.
it sounds fooked already mate blowing the cap off is bad maybe a few more checks should have been done before takeing money off you for a remap.
its weird thou coz i,ve taken it out 3 times now and booted it but not had the cap blow off, it doesnt smoke doesnt knock and runs well when driving, its just the idle.
