rs2000 4x4mk6
bah its on the tip of my tounge. Iam pretty sure it sits just under or above the thermostat housing. Its usually around a 13mm - 15mm socket you can get on the end of it (once you remove the wire from it) very simple thing to replace
i maybe confusing it with zetec or the rs2k but i swear ive seen one sit in the housing of the thermostat - confused.com
I can check when i get in.
i was right just found an old photo of mine, if you locate the thermostat housing the piece of plastic , from memory its the top one thats pointing towards the bulkhead and again around 13mm to 15mm in size and has a connector on the top (squared) usually a couple quid from a motor factors, when replacing you may need to top coolant up again etc
Pwrs2k
120
16-10-2015 03:16 PM
Fordmad!
15
27-09-2015 06:24 PM
