Possibly caught by a GATSO...
PassionFORD Member
Evening guys,
I'm turning this over and over in my head but just making myself confused and worried for nothing really so want some advice if possible.
Basically today was going up a dual carriageway 40mph limit and I know that I am approaching a speed camera (old type GATSO). There was a police car with blue lights coming into the dual carriageway so I braked and let him go. Cos I knew there was a speed camera I was interested to see whether it would flash the cop car as it wasn't absolutely rocketing up but had blue lights on with no siren. Consequently I wasn't concentrating on my speed. I was doing an indicated 44-45mph on my speedo. I caught the camera out the corner of my eye and slammed the anchors on almost instantly and dropped the speed to 35mph. I looked in my rear view thought phew no flash and then carried on. I kept looking though and saw a Rover passing the camera and I *think* I was clear of the lines. This is where I am shitting bricks for not being completely sure if I was caught or not because from what I remember I was pretty clear of the lines if not totally at the end. The Rover passed the camera and then it did a double flash but I couldn't tell if the Rover was speeding. So am I sitting on hot coals for the next 3-4 weeks to see what happens or have I just been fucked over? What do you guys think? What's the period of time the letter must arrive by for it to be valid or when does it need to be printed or whatever?
Thanks!
Thanks!
if it flashes twice ya caught a seen this the other day early in the moring some pratt come flying past me and i thought ya gonna slow down now cos there is a camera up ahead, did he hell lol and it flashed twice, think if ya do get caught they have to notify you within 2 weeks also
Never gonna give you up!
Tim
PassionFORD Member
Think it's going to be one of these wait and hope ones tbh as nobody can really give any advice unless they were there or hope the GATSO isn't loaded. Will sit and wait unfortunately as that's all I can do
Right think about this for one second,the faster you go the more distance you will cover,so if you were at the far end of the lines doing like 35-40mph then the camera would not be flashing for you as the first flash is for the start position and the second is the finish position, the distance covered between first flash and second flash will be then calculated in to a speed,if it got you, then you would be doing near on 140 mph at the far end of the lines, so i think you will be in the clear.
Guest
Posts: n/a
just that ive seen it go off in the past.
Obviously your gonna have a bit of a nervous wait to see if it was you but going on what you said I'll think you'll be unlucky to get caught out. The NIP has to be issued within 14 days so it could take a few days longer to arrive. (16-18)
PassionFORD Member
Thanks for the advice guys much appreciated!
PassionFORD Member
I know I realise I might be making a bit of a mountain out of a molehill here but I'm 19 turning 20, already claimed previously and seriously trying as hard as possible to keep clean. I am the policy holder as well and already paying enough as it is so would like to build up a clean enough licence and no claims in order to get something decent in 2-3 years time. This won't help.
by the sounds of what you`ve said there is no way you will get a ticket. the speed camera has to identify a smooth speed through it`s path to indicate if you was speeding but as you said you slammed on the brakes there is no way it can register a rough speed.
reasen how i know this coz one of me mates repairs them!!!! what a w*&^$r! hope this puts your mind at ease.
Stop worrying most speedos overead anyway!!, not all piccies taken result in a NIP, which as said has to be issued in 14 days.
Most are st to go off at the limit plus a certain amount anyway, it needs to capture you on TWO piccies as time/distance = speed, the lines are used as they are a known distance apart , the camera can capture you going towards or away on either side of the road, even if the lines are only on one side.
No police car on any emergency has to avoid the cameras as they are allowed in law to speed if the circumstances warrant it, so they just check the log of grade 1 calls etc.
burnzy
i had the exact same thing happen to me on the M42 with all them new variable speed cameras and we was doing 60 and the speed went down to 50 i slowed down myself but was chatting to a mate and just in the moment and noticed the camera flash behind me and i also had a car coming up from behind me but he must of been going faster because he had nearly caught up with me by the time it flashed, i looked at my speed and was doing about 57 on the clock but my satnav was saying 55 so was worried like yourself esp cos i can't afford any points, but it's been a good 3 week's now and haven't heard anything so hopefully your lucky mate, the bloke behind prob's only needed to be a couple of mph faster to set it off so you might not of noticed the difference
i'll have my fingers crossed for you
Shizzle My Nizzle
On a serious note tho, like you say your self there is nothing you can do about it. I wouldnt worry yourself too much, if it got you, it got you, youl find out in 2-3weeks.
I personally have never had a speeding ticket, but as far as im aware most insurers dont even blink at 3 points for speeding. Especially if its something like 44 in a 40.
Also, tho im not entirley sure what truth is in this, but ive been told that in a 40 for example you will 9/10 times be ok if your flashed at say 43, as im sure they allow a small grace of up to 5mph some times, due to the fact that not all cars are going to be calibrated exactly.
Clutching at straws here bit i also notice you have aftermarket alloys, it may be worth working out the OD of these compared to the factory items, even an increase of 1/2" will slightly affect your speedo. So you car may read say 42mph, but due to the bigger wheel your really onle doing 40.
Anyway, lets hope your ok. I wouldnt loose sleep over it tho matey.
If he's got bigger wheels diametre wise, he will be going faster than indicated, the old "rule"(although was never a rule!) was 3mph plus 10%, so that's 47mph in a 40.
Thats the yardstick that a lot of Police use (all the Police I deal with say in most cases they give 10% + 2mph) but there is no such rule with speed cameras as your speedo (unless faulty or otherwise not working propperly) should always read faster than you are actually going.
Resident Wrestling Legend
on another note, the one on the bypass as you go towards pump lane from southall flashes you both ways, but my brothers mate got done for doing 70 along there years and years ago
