photoshop is driving me mad. help!!!!!!!
only a quick one , ive found how to resize the actual pic by changing the pixel thingy etc but how the f*ck do i change the kb or mb thing. ive got a pick which is 1.21 how on photoshop do i lower this...... ive done it before but i just cant remember................anyone help me
cheers mate but i cant figure out that way either . im sure it had to do with me changing the resolution of the pic and as i did it the kb/mb size was changing at the same time.........
get pic to size you want (pixel size), go to file, click on save for web, you should have a menu on the right, click on quality and move the slider to alter the file size, save. job done
i havent got the option of quailty. buts that what i want i want keep the height and with but make it not so clear so it lowers the kb size??????????????
When you click > save for web in the pop up window is your setting set to Original ?
If it is use the drop down link to select JPEG Medium. Then you should get a quality tab Then adjust the slider to see the changes to file size under the picture
Whwn complete just save the new pic
07-10-2015 12:56 PM
SMILER258
28-09-2015 09:04 AM
