Adding steering wheel controls
Old Jan 19, 2009 | 06:58 AM
pacwest's Avatar
pacwest
Puller of the Wrench
Default Adding steering wheel controls
SO I have a new ECU that has launch control. It uses a button/switch of course. I wanted it on the steering wheel but then decided to go with a clutch switch. Then I realized I want to rev my car sometimes liek when matching revs for downshifting.
So I want it on the wheel again. No tether. I tried a mock up of the tether and it just turned my signals and wipers one with the coiled wire (like a telephone cord).
I've see different models of SWI JACK and still can't find anything other than maybe retrofitting a one wire cruise setup and pissing about with it.
Am I missing a kit that's available for horn and 2 or 3 switches to go through the one wire setup? Reading some resistance values and then dropping a ground? I'm no electronics whiz but I sure wish I was with this stuff.
Old Jan 19, 2009 | 10:06 AM
LINCOLN's Avatar
LINCOLN
I bought a normal keypad control unit with a relay board - similar to an alarm control - once you strip out the button and plastic surround it fits easily behind the steering wheel.
http://www.oceancontrols.com.au/cont...r%20boards.htm
Then some nice 16mm push buttons.
Old Jan 19, 2009 | 08:07 PM
LINCOLN's Avatar
LINCOLN
Or you could use one of these.
http://www.oceancontrols.com.au/controllers/pixel.htm
And as you say add some different value resistors through buttons to ground (voltage dividing). The kit has a regulated 5v - wire to analogue input and horn wire and switch relays based on different voltages produced by switching buttons with resistors to ground.
charlierothwell
Ford KA
Nov 5, 2015 06:56 PM
Adam Graham
Sep 6, 2015 06:04 AM
rsturbo27
Sep 5, 2015 05:08 PM
andrewmctiernan
Wheels and Tyres
Sep 3, 2015 08:22 PM
3dr cossie
Alloy wheels and ICE for sale
Sep 2, 2015 08:58 PM
