transit wheels
Old Jan 15, 2009 | 08:43 PM
Basky's Avatar
Basky
Default transit wheels
does anyone know if the new st wheels fit the mk5 transits
or know which other alloy fits.
Old Jan 16, 2009 | 06:00 PM
James's Avatar
James
no, you'll need transit alloys.
Old Jan 16, 2009 | 09:01 PM
Basky's Avatar
Basky
the transit st ones
Old Jan 17, 2009 | 09:11 AM
fordrs2005's Avatar
fordrs2005
can u not get a hub adaptor kit for them so they fit ?
Old Jan 17, 2009 | 06:08 PM
MrMPuk's Avatar
MrMPuk
Originally Posted by Basky
the transit st ones
You mean the Transit SportVan, no they wont fit. 2000 on Transit use 14mm studs and are hub centric, pre-2000 use 12mm studs and are stud centric.
Old Jan 17, 2009 | 06:28 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
the transit st ones
will also need adaptors to run sportvan alloys
was a bloke on flea bay selling `wobbly bolts` that meant you could fit landrover alloys,whether you would trust em is another issue
get some tourneo ones they are for sale every now and then
Old Jan 17, 2009 | 06:32 PM
paul16v's Avatar
paul16v
Monte 087
Be very careful when putting alloys on a transit, alot of wheels are not up to the job due to the weight of the van.
Old Jan 17, 2009 | 06:38 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
good point,thats why i took the alloys off my cossie transit and stuck steelies on,that and wanted more of a sleeper look also dont think the tyres were up to it either
Old Jan 17, 2009 | 07:06 PM
Basky's Avatar
Basky
any info on the adapters?
Old Jan 17, 2009 | 07:17 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
none at moment will look when i take my tyre for its puncture to be done
Old Jan 17, 2009 | 07:28 PM
Basky's Avatar
Basky
cheers, got a friend who,s a machineist and could possibliy make some if cant find any to buy.
Old Jan 17, 2009 | 07:33 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
just thought have one of the wheels as a spare that ford gave me when i got it cos delivery driver buggered it,will take a look at its et and anything else on it so from that and the info about ya mk5 offset etc you should have enuf info
Old Jan 18, 2009 | 10:10 AM
MrMPuk's Avatar
MrMPuk
Even with adaptors it's not easy, you'll end up with the wheels sticking out past the arches. As said above you need wheels that are rated for the weight of the van, adaptors wont be rated.
There are plenty of options out there that have the correct fitment and are rated for the weight. In fact I have this set for sale.
Old Jan 18, 2009 | 11:56 AM
Basky's Avatar
Basky
its only transit 100,so it cant carry much anyhow
pm me size and price please inc tyre sizes
Old Jan 18, 2009 | 03:04 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
right mate
rear adapter 33mm thick
front adapter 22mm thick
pcd 160,et 50 on sportvan wheel
tyre size 235/45/18
hope this helps you if you go for sportvan rims,tho easy option is rims for sale above
Old Jan 18, 2009 | 03:19 PM
neil117's Avatar
neil117
part of the bonus crew!!!
sportvan rims are about 1200 quid i'm sure and thats before you put tyres on them
Old Jan 18, 2009 | 03:24 PM
Cragrat's Avatar
Cragrat
sit boo boo sit
sounds about right,£150ish a corner for tyres
ossie cossie
Sep 21, 2015 05:07 PM
cliffy70
Sep 20, 2015 09:18 PM
Mark RS
Alloy wheels and ICE for sale
Sep 10, 2015 07:27 PM
povey@pembrokeshire
Wheels and Tyres
Sep 9, 2015 06:44 PM
Adam Graham
Sep 6, 2015 06:04 AM
