Upper front Strut Top mounts
I priced these from GGR which are the genuine group n and also priced normal ones with ford part number 6150277
Are these the same things or is there genuine group N ones and would i be better getting the ones from GGR
Also the strut bearings are around £20 from what i can see but only about £4 each from ford part number 6150276 is this correct?
Thanks
Thanks
I had the top mounts if you are reffering to the insulator that is on the underside of the top mount area, the group N ones I had were just a harder rubber, but poly is cheaper and just as good.
The bearings I used were std ford ones.
jessie_rs
11
03-06-2019 04:57 PM
RIB1122
12-08-2015 08:49 PM
track.focus'd
12-08-2015 05:53 PM
