2.1 ZVH Questions.
2.1 ZVH Questions.
I have changed me mind again and i am now going to build a "2.1"? ZVH I have all my parts ready and i am using forged XE pistons, Now i know i have to modify the conrod to fit the bigger gudeon pin.
But is that all the work needed to do to the piston and rods?
Also i am using a 2.0 Blacktop bottomend so all i need to do is rebore to 86mm and do the ushual ZVH mods?
Any help/info would help.
Cheers Stu
Cheers Stu
This is one of the many i have built using the same pistons you are using, may help you out,
https://passionford.com/forum/restorations-rebuilds-and-projects/227173-new-zvh-dyno-results-10-03-08-a.html
https://passionford.com/forum/showthread.php?t=227173
Also i am getting my head ported while its off.
^^^ yeah, you'll have to swap pump to a silvertop one as the blacktop rotates the wrong way. I'd also check the block heights or speak to someone who has done a Blacktop ZVH before
