where can i get
dont know if its the same on all of them but its usualy the bearings on the shaft that fail that causes the damage but it usualy fooks the casing aswell. the bearing spins in the casing
(i think you can get oversized bearings ) but you have to get the casing machined for them to fit this is what happened to mine anyway.
so you might want to check this out before you rebuild it
