castor angle
Old Jan 9, 2009 | 08:59 PM
andy escos's Avatar
andy escos
Default castor angle
can some one give me the castor ,camber,&toe 4 a escort cosworth 4 fast road ,track use thanks.
Old Jan 9, 2009 | 09:30 PM
J1mbo's Avatar
J1mbo
B1mbo
hi mate, pm mike rainbird he will know them off top of his head
Old Jan 9, 2009 | 09:52 PM
andy escos's Avatar
andy escos
already have m8 still waiting 4 reply clocks ticking though
Old Jan 9, 2009 | 11:11 PM
jon@work's Avatar
jon@work
by Mike R :
Fast Road Geometry settings:
Front: 1.5° negative camber, 2mm toe-in.
Caster as close to 3’30° as you can get.
Rear: 1.5° negative camber (not adjustable on standard rear beam, but will normally be around this depending on ride height), up to 3mm toe-in (using shims or by slotting the mounting points and tack welding the beam in position after welding – as per the Grp N cars).
Track day Geometry settings (you will need adjustable TCAs and rear beam to achieve these settings):
Front: 3° negative camber*, 2mm toe-in.
Rear: 2.45° negative camber, 3mm toe-in.
*Please note when running such aggressive negative camber on a track car that is 4wd, longer drive shafts may be necessary and also ball jointed top mounts are recommended, so as not to put excessive load on the damper
Fezman1
Oct 2, 2015 01:22 PM
landaqmabba
Sep 15, 2015 07:16 PM
JC
Aug 7, 2004 08:35 AM
neilm
Nov 3, 2003 12:39 PM
