i need help!!!
Old Jan 4, 2009 | 11:53 AM
theburns1's Avatar
theburns1
cannock is a race track
Default i need help!!!
i've built up my engine and now finally got it on the road its a 1.6 cvh, with twin 40's on it xr2i cam, ported polished head, four branch and a vernier pulley. runs and drives fine untill it hits 5000-5500 rpm then it missis and sluters like theres not enough fuel getting to the carbs. i turns the regulator up abit and it made it worse. some times this does not happen and it pulls strrong all the way up to 6k.
any ideas? please help
Old Jan 4, 2009 | 11:54 AM
boothy's Avatar
boothy
get it to a tuner ,and have a set up
Old Jan 4, 2009 | 11:57 AM
theburns1's Avatar
theburns1
aldon automotive have already done it. ment to be the best around the mids for carb set ups
Old Jan 4, 2009 | 12:00 PM
dave cos4x4's Avatar
dave cos4x4
take it back to them.
Old Jan 4, 2009 | 12:05 PM
COLEYST200's Avatar
COLEYST200
i second that mate
Old Jan 4, 2009 | 12:11 PM
mechanic28's Avatar
mechanic28
i had twin 40's on my xr2 nothing but grief!!!does it stutter when you give it full beans through all the gears and say u get to 3rd gear it then stutters at 5k
Old Jan 4, 2009 | 12:13 PM
LHD220Turbo's Avatar
LHD220Turbo
i second that mate
+3
Old Jan 4, 2009 | 12:25 PM
theburns1's Avatar
theburns1
1st to 2nd is fine. revs perfect. 2nd at 5000rpm and some times in 3rd. typical ford problem its very temprimental, lol
Old Jan 4, 2009 | 12:48 PM
mechanic28's Avatar
mechanic28
is she spitting back through the carbs when you are driving?
Old Jan 4, 2009 | 12:54 PM
theburns1's Avatar
theburns1
wen its cold yea.
Old Jan 4, 2009 | 12:57 PM
mechanic28's Avatar
mechanic28
thats ok as long as she settle down when warm!problem with twin 40's u always need to balance them!sounds like its running out of fuel to me!i presume you have fitted a electric pump?
Old Jan 4, 2009 | 01:01 PM
theburns1's Avatar
theburns1
yep, a facet gold top. fuel regulator is on 2.5 psi tried it at 3 and it was worse. any ideas?
Old Jan 4, 2009 | 01:16 PM
mechanic28's Avatar
mechanic28
could be a number of things tbh!wrong jets in the carb etc!!really needs to go back or put on a r/r for a set up
Old Jan 4, 2009 | 01:25 PM
mark_24v_wiring's Avatar
mark_24v_wiring
My old one used to run like a bag a crap till i had it setup properly on the rollers so as everyone else if you have had it setup then get it back to them asap
