mobile mechanic/someone who knows there stuff about s2
Old 04-01-2009, 11:35 AM
Smartdj.
Smartdj.'s Avatar
Default mobile mechanic/someone who knows there stuff about s2
i really need somone to come and fix my car for me as im so stuck with it and confused why it wont run iv replced everything i can to make it work..it should just fire up .it fires then just stops straight away no matter how much gas u give ....is anyone near bournemouth wants to earn so money reply please
Old 04-01-2009, 11:37 AM
leejones09
leejones09's Avatar
have you checked all the main stuff mate
Old 04-01-2009, 11:39 AM
sortedsaff
sortedsaff's Avatar
as you know mate id do it if i wasnt 6+ hours away lol
theres some good lads on here im sure someone will help in your hour of need.
Old 04-01-2009, 11:40 AM
sortedsaff
sortedsaff's Avatar
i went though all the main stuff with dan but theres only so much we can do over msn . and not being there to see/hear etc lol
id put money on it being something silly
Old 04-01-2009, 11:41 AM
Smartdj.
Smartdj.'s Avatar
lol i think so iv brought new leads plugs dizzy cap...dizzy was new anyway...oil/filter it has plenty of gas .....fuel pumps priming.....gas is geting to the pots...battery is fine...amal valve removed .....brand spankin boost pipes...new metering head
Old 04-01-2009, 11:43 AM
leejones09
leejones09's Avatar
is the fuelling setup
Old 04-01-2009, 11:44 AM
Smartdj.
Smartdj.'s Avatar
well not alots changed sinse i changed the bottomend
Old 04-01-2009, 11:46 AM
sortedsaff
sortedsaff's Avatar
iirc it ran fine then you changed the bottom end and its fannying about now aint it dan?
Old 04-01-2009, 11:48 AM
Smartdj.
Smartdj.'s Avatar
this geeza is a top bloke he has helped me so much over the last weeks with my car i think i o u about 5pints it will work
leejones09
leejones09's Avatar
have you done a compression test
Smartdj.
Smartdj.'s Avatar
yes m8
Old 04-01-2009, 11:49 AM
Smartdj.
Smartdj.'s Avatar
no m8
Old 04-01-2009, 11:51 AM
Smartdj.
Smartdj.'s Avatar
tbh i think it is somthing to do with an air leak or somthing is wrong like the brether system i just dont know anymore
Old 04-01-2009, 02:50 PM
Smartdj.
Smartdj.'s Avatar
upski
Old 04-01-2009, 02:57 PM
Big Will_
Borg Warner EFR Equipped!
Big Will_'s Avatar
Location: In the unit, building a 450bhp Time Attack Focus!
Can you get it to start at all - i.e if you crank it over at full throttle/operate the metering flap manually?
Old 04-01-2009, 03:23 PM
Smartdj.
Smartdj.'s Avatar
if u crank it at full throttle after a while the engine will stop sudenly .....it does fire and sound like it wants to run but i cant get it to keep going...doing my nut in.....befor the changed the bottomend it ran fine but with a nock so i changed it and now it dosnt work atall
Old 04-01-2009, 03:24 PM
Smartdj.
Smartdj.'s Avatar
i ws thinking a valve is not opening at first but im no mechanic and cant tell
Old 04-01-2009, 03:27 PM
Smartdj.
Smartdj.'s Avatar
forgot to mention the only time iv had it running it sounded like a lawnmower is the only way to discribe it......there nothing that can change the fireing sequence is there? 1342 or 180 iv tryed and wont work
Old 04-01-2009, 03:33 PM
105epwr
105epwr's Avatar
have you got the plug leads on the dizzy cap the right way round in respect to direction of rotation?
Old 04-01-2009, 03:39 PM
Smartdj.
Smartdj.'s Avatar
anti clockwise 1342 from cam end? that the way iv done it
Old 04-01-2009, 04:24 PM
Fiecos Dan
Fiecos Dan's Avatar
So what have you
done, touched, changed since it run last time?
Old 04-01-2009, 04:30 PM
smila
smila's Avatar
mine was like that and the leads was not on right,i would say leads or dizzy wrong?
Old 04-01-2009, 04:31 PM
Smartdj.
Smartdj.'s Avatar
bottomend that it....plus metering head ...but it didnt change anything still the same prob
the bottomend is system2 and i know its fine .it came out of a m8s car
Old 04-01-2009, 04:35 PM
Smartdj.
Smartdj.'s Avatar
https://www.burtonpower.com/product_main.aspx?home.aspx
i have the prospark ones right at the bottom of the list for escort rs turbo ...just to get it running
Old 04-01-2009, 04:37 PM
Big Will_
Big Will_'s Avatar
Have you double checked your cam timing? Is the rotor arm pointing to Number 1 HT lead contact when the cam/bottom end is timed up to TDC on cylinder 1?
Adam.
Needs Beer Tokens.....
Adam.'s Avatar
i had a loada hassle with the metering head when i changed it, is ur mates car running more/less bhp then your car? if there is a big difference the metering unit will need adjusting (well thats what i had to do) hope this helps
Oranoco
Oranoco's Avatar
Have you checked the solid plastic pipe that goes from the breather filter on the back left of the rocker cover to the base of the metering head. Any airleaks or cracks in this can be detrimental to the car running or starting at all.
ian r
ian r's Avatar
is the flap in the metering unit moving up and down as you crank the engine ?
Old 04-01-2009, 04:38 PM
rs-nut-john
rs-nut-john's Avatar
Sounds stupid but try some diff leads m8, even new ones can be faulty
Old 04-01-2009, 04:39 PM
Smartdj.
Smartdj.'s Avatar
it definitly is
Old 04-01-2009, 04:41 PM
DAZ1RSNUTS
DAZ1RSNUTS's Avatar
have you checked the pink fuel pump re lay under the dash, they burn out and can cause intermitent failures
Smartdj.
Smartdj.'s Avatar
i did check the piece i could see yesterday and it had been rubbing so i taped it up for a tempory fix intill i get a new one ...i think ill remove the whole pipe first thing in the morning
Old 04-01-2009, 04:42 PM
Smartdj.
Smartdj.'s Avatar
should it move???????
Old 04-01-2009, 04:47 PM
ian r
ian r's Avatar
what i have done before when i have suspected a air leak get sombody to crank the car over and watch if the metering flap moves down which it should if its not push it open but only a little bit and it should fire
Old 04-01-2009, 04:52 PM
Smartdj.
Smartdj.'s Avatar
ok man ill try tht in the morning aswell
Old 04-01-2009, 04:54 PM
ian r
ian r's Avatar
if you were closer i would come and have a look
Old 04-01-2009, 04:56 PM
Big Will_
Big Will_'s Avatar
What was wrong with your original metering head?
Old 04-01-2009, 04:59 PM
Smartdj.
Smartdj.'s Avatar
i seem to live miles away from everyone ....ok im off now iv been sat here all day lookin for someone to come and fix it who knows what there doing and dosnt live halfway across the contry all iv maneged to find is a stinking headache..i really dont want to take it to a garage who know fuck all about rs's and fuck it up even more that she all ready is...thanks for everyones in put today much appreciated it will run by the end of january
Old 04-01-2009, 05:00 PM
Smartdj.
Smartdj.'s Avatar
probaly nothing i was told it was that so i replaced it
Old 04-01-2009, 05:44 PM
rst in breaking
rst in breaking's Avatar
was the timing fiddled with on the dizzy?
Quick Reply: mobile mechanic/someone who knows there stuff about s2
