cossie track car guys...
http://cgi.ebay.co.uk/New-Modified-S...742.m153.l1262
i have a big wing sump, but its not gated or have any baffles in it,
do you reckon its worth fitting this?
mate of ours got one , Kirky. got one of Burton and had to send it back as he couldnt get it to fit correctly.
But in principle yes good idea,, if it fits ,, just make sure they will have a returns policy
Yours is a 4WD sump I guess? I am just fitting a Burton baffle to my 2WD Sapph sump. No need for big winged sump I think but the baffle is important.
Last season my oil pressure warning light came on a few times under braking at the end of the straight at Brands and at the long right hand corner at Snetterton. This is why I'm fitting one.
Mine is the Burton one - I hope it fits OK.
Charlie
Charlie
That looks exactley the same or is a copy of the Mountune GRP N baffle (i have the mountune one). IF you look close you will see that one on ebay DOES have 2 gates on it, the one at the top of the picture is open, and there is one directly underneath which is closed.
I'd say yes it is worth getting.
In answer the original question that this thread was about. Yes I would fit one if I was you Jtech. I run one with my 2wd setup on the Westy which probably generates more chance of oil surge and its been fine.
I can get them made for 2WD and 4WD fitments if you want one.
The guy above who had problems fitting. I bet your sump has been thumped on the ground at some point meaning that the baffle would not bolt down properly? The sump will probably look fine but the bottom is probably sitting up a mm or 2.
on the extended part of the sump are there holes, or is it cut completely out to
is the 4wd more prone to surge than the 2wd one
My Cossie Ate My Money
not sure mate
i've only ever enquired about the cossy stuff
but i've heard him talking about working on other stuff
and he does it all himself so i dare say he could do other stuff
very easy going guy to talk to, pm him and he'll be able to tell you for sure mate
I bought a 2wd 1 from burton for mine. It was a proper pile of wank!! badly made, rusty and still had loose bits of metal in it and hanging off it. When i phoned up to complain about poor workmanship etc he said "well your not going to see it and it will be covered in oil". Needless to say i sent it straight back and made my own.
RIB1122
13-08-2015 09:09 PM
track.focus'd
12-08-2015 05:53 PM
Versus_Creations
24
05-08-2015 09:32 PM
