mahle pistons
Rods are identical, If you need any spare rods drop me a line I have a couple spare you can have.
Pistons are different, 4x4 has an offset gudgeon pin so stops the 2wd piston slap when it is cold, I would use 4x4 pistons if you can.
Super Moderator
rods are different there is a "light" and a "heavy" rod,difference being the counter weight above the little end,so make sure you have a match set,also the 4wd pistons have a different size bowl in the piston which will effect yout compression ratio,persoanly I what ever pistons you use gets them decked and bowled oout the decking will avoid any pistion to valve contact which all cossy engines had even from new,so you will get even more conatact as your head will have been skimmed at some point
The Cos manual says that the heavy/ light rods are marked as such, standard are not marked, but over the years I have seen loads marked with S, and loads with pin punched dots indicating 1-2-3-4, so I think the best thing to do is just get them balanced when you build the engine.
IV GOT 2wd rods at the mo which are still on the standerd pistons but iv had it bord out to +5 pistons as the motor went sick . the lad has got 4x4 +5 pisons with the 4x4 rods would they go straight in . im going to have wot ever pistons i get pocketed out as in putting bd14 cams in martin at rayland is going to be doing this for my
deathrider666
28-09-2015 06:12 PM
timsrs
22
24-09-2015 08:14 PM
