Not kicking in
Not kicking in
i had trouble with my alternator, that is fixed now
but when driving down the road, my car seems to not kick in, it a escort 1.8i
even when my foot is to the floor there seems to be no get up and go
i have changed the spark plugs as that was done 2yrs ago
any help on this wood be great
had same problem on an old escort Si 1.8 - turned out to be the Air Flow Meter - i'd go to pull away from a junction or onto a roundabout and the car would have no power at all then all of a sudden kick in...very dangerous especially when your not expecting it.
car starts fine, but when pulling off it kinda holds back then all of a sudden it wood go even with my foot to the floor it takes a while to get up to speed
the air flow meter is the plastic box with wires going to it (check these are also fitted correctly) that is attached to the airbox or air filter,whichever you have fitted.the other end is then attached to pipework which leads to the throttle body on the inlet manifold.make sure it is all attached to each other properly,no gaps or pipes or wires unattached etc.
cameron2
06-09-2015 10:42 AM
