exaust manifold waste gate relocation
YES I KNOW I CANT SPELL
hello take a look at this pic
its off a nissan 200sx but im cuting the flange off and replacing it with a zetec one
but where the waste gate sits will poke through my rad
what i wanted to do was move it on to the top in the middle of the 4 pipes but im not sure if this will be ok as all the ones i have seen are kind of mounted in the direction of the flow if that makes sence
what are your thorts
Borg Warner EFR Equipped!
Location: In the unit, building a 450bhp Time Attack Focus!
Think of it like water flowing through the manifold - how easy a path would it be for the water to reach the external wastegate
The answer to your problem in my mind would be to blank the take off where it is currently and have a take off from the collector area before it enters the turbo on the hot side - go through the external gate and back into the downpipe.
Or put your radiator somewhere else
Baby Cheesus
it looks like your missing a part mate, my xs power manifold and wastegate had another pipe to space the w/g away a bit, and also alter the angle etc.
and are you planning on welding it to the zetec flange as per you pic so the turbo mounts at the bottom? other wise you may have a small issue closing the bonnet lol.
i dont seem to have any pics of the pipe, but i still dont think you will have enough room for it anyway being fwd. your possibly gonna need a custom effort
You can run GT30s both internal and external gate - all depends what sort of boost you want to be running, what hot side the turbo is available with, how big the wastegate penny is, whether boost creep will be a problem etc. etc.
07-10-2015 12:56 PM
caprixpack
25-09-2015 07:53 PM
