ford escort diesel head/cams are they the same as tddi?
reason im asking is ive just had a tensioner collapse on my tddi focus after fitting new timing kit and chain . i'm going to try and whipp the head of at some point to inspect the damage but was wondering if they're the same heads? any help much appreciated
MERRY CHRISTMAS TOO lol
heads are differant mate, few differances but the older ones are no use i'm afraid
i've got a complete good head for a 99 focus tddi in the garage that i could let you have cheap
i'm wanting 100 quid for it, must be cheapest around, i paid 250 for 1 not to long ago
drop me a pm mate if your interested mate
well car was running yesterday, and then stopped running (had been started up about 9-10 times) then just couldnt work out the problem, so stripped it down a while ago and tensioner had collapsed (old one still tensions belt) but has snaped the cam .
bbe monday before posty opens mate to send it to you so be after new year before it gets there, your welcome to sort out a courier if you like, you can send me the money once you've got it and seen its fine( i know it is as i took it off the engine and it was running fine)
options there for you mate if you need it anyhow
as said earlier the heads aren't interchangable, injectors mount differant and combustion chambers atc are differant
thanks alot mate, really appreciated, will try and get one locally so i'd be able to crack on with it asap, may be a case of just a few valve at the moment who knows? lol
ive mastered the engine now tbh, had it back apart in no time now i know whats what but just the fooking tensioner fucked up so have to take collapsed tensioner back and fill out warrenty form. Would i be best getting a couple of garage documents saying its caused by the tensioner? as proof as its the reason for failure. sisters bf also checked the timing and belt before hand and knows these engines and said was bang on and so was tension so i know its no error of mine
ive said if they wish to come and inspect that the tensioner will no longer go tight in any position and the old one will so regardless weather my profession is a mechanic if it was too tight it would have done the belt, too loose and it would have thrown the belt and not done tensioner so i dont see thier argument really?
best of luck anyhow mate
you'll get warranty on the tensioner no prob
but you'll have a fight on your hand to get anyfin for the rest of the damage
YES I KNOW I CANT SPELL
they wont come and inspect any think they will want to see a recite from the garage that fitted the part regardless weather the part is faulty
they will try every think to make it not there fault mate
matman
09-09-2015 05:45 PM
