brake fluid questions
Got this in alex's and mine
Wilwood High Temp 570 Brake Fluid
• Minimum dry boiling point of 290°C (570°F). Lubricates and cleans your brake system's internal parts. This is an essential element for a brake system to operate at 100% efficiency.
• Due to Hi-Temp 570's low viscosity, bleeding brakes becomes an easy operation. Problems with aeration of brake fluid dueto foaming from excessive pumping of the brake pedal are eliminated.
• Hi-Temp 570 comes only in a hermetically sealed container to guarantee against unwanted absorbtion of moisture which can drastically lower the boiling point.
just finding my feet
faye did YOU actually write that or have ya just copied and pasted off raldes's site
actually i was talking about just bleeding with normal castrol dot 4 fluid, not srf, thats what im gonna stick in the cossie
this is for me cabrio
The Enigma
12-09-2015 10:12 PM
