Closed Loop MPG
Old Dec 13, 2008 | 08:22 PM
  #41
RS Grant's Avatar
RS Grant
Made in Scotland
Originally Posted by JTECHSAFF
a full closed loop kit is around £400 iirc, thats the whole lot.
closed loop needs an L8, then its just a chip and a lambda sensor
Thanks mate.
Cheers,
Grant
Old Dec 14, 2008 | 12:18 PM
  #42
Stu @ M Developments's Avatar
PassionFords Creator
Originally Posted by jammerrs
i no i am thick but what does this wasted spark and closed loop stuff actually do? im always confused when i read about cars having it in mags
Some light reading for you:
Closed Loop:
http://www.motorsport-developments.c...losedloop.html
Wasted Spark:
http://www.motorsport-developments.c...stedspark.html
And its worth noting how incredibly cheap it all is in our Xmas sale!
http://www.newzapp.co.uk/default.asp?LID=OSw3NjAzOTc1MQ
Old Dec 14, 2008 | 12:22 PM
  #43
Originally Posted by Jay.
col ive seen loads of cossies @450bhp+ on a group a coil and never having issues with idling or missfires ,look at all the old turbo systems cars for example ! the advantage as i see it to a average cossie is just more reliability
Far more reliability, less maintainance required, better fuel consumption, often improved engine life and more power in many cases.
Old Dec 14, 2008 | 12:26 PM
  #44
Originally Posted by RS Grant
What sort of cost is involved to run Closed Loop and Wasted Spark on a Cossie??
A late cossie already running one of my chips can have closed loop for as little as £100.
Full kits for up to 803s in my Xmas sale:
Evolution Chip (up to 803s)
Closed Loop key and software
Lambda sensor
Full colour instructions:
Total: £175 inc vat!!
For bigger than 803s.
Evolution Chip (up to 55lb Siemens)
Lambda sensor
Total: £275 inc vat!!
Wasted Spark Kits comprise of:
Driver for your ECU.
Second Ignition Amplifier.
Bracket to mount 2x amps.
Special sub loom to connect it all together.
Coilpack.
HT Leads
Full colour Instructions.
All this for only £360 in my sale! Its a no brainer!
Wasted Spark full kits are only £360 in my sale! Its a no brainer!
Old Dec 14, 2008 | 01:09 PM
  #45
Jay,'s Avatar
Jay,
Sponsor
from a coil on a properly mapped car ?
Old Dec 14, 2008 | 04:49 PM
  #46
Dan's Avatar
Dan
Mine averaged about 32mpg on a T3 and Greens mate, this was ALL type's of driving from sitting in cue's to sitting abpve 140mph so a true average!
What did your's do Steve?
Old Dec 14, 2008 | 04:59 PM
  #47
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
........rubbish.........u must have been sat at 50mph for 299 mile then done 1 mile at 141.............
Old Dec 14, 2008 | 07:01 PM
  #48
RWD_cossie_wil's Avatar
RWD_cossie_wil
Why do people try and fault MAJOR improvements that make a Cossie much more livable with? If I had the choice between dizzy and rotor arm, and closed loop or just a decent chip ( which off someone like MSD is good in the first place) it is a no-brainer!
Yes it can work fine on the old system, but why not upgrade to a FAR superior method of doing things?
Old Dec 14, 2008 | 07:18 PM
  #49
pete mcrash
........not "faulting" fuck all..........just saying sometimes it aint needed.......life beee---onnn---dddd passionford n all that........where people think this place is "god"............ta
Old Dec 14, 2008 | 07:31 PM
  #50
RWD_cossie_wil
I have personal experience of it on a number of cars, including my own T4 saff with 850cc injectors, I just think you are being a bit blind thats all.! Big brakes aren't NEEDED, but are a huge improvement over the std jobbies
Think you ought to try it Pete, perhaps if you ask Stu he might do you a Daz doorstep challenge , and swap it back for free if you don't like it
Old Dec 14, 2008 | 10:27 PM
  #51
2wd's Avatar
2wd
I run C/L on T34, siemens 55's and Wasted Spark and so on, and I run 10.7 to 11,6 km/l doing all type's of driving from cue's, around town to doing 150 km/t .. and I'm quite happy with that...before I did around 9,2 to 9,8 km/l under same conditions ..... and no misfires
Old Dec 15, 2008 | 09:05 AM
  #52
pete mcrash
........sounds good ta me..........tbh was tempted by his xmas deal but if i was to improve/spend on my ignition system i think i would start with a new loom
Brickhouse
14
Oct 3, 2015 07:28 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Marv888
Sep 26, 2015 03:44 PM
tib2220
Sep 14, 2015 12:33 PM
