ERST poor starting from cold-ish problems...
#41
#1 in Spelling Club
James, when you say that the Cold Start injector isn't being used, is it just unplugged?? It could still be weeping as it still has a fuel supply to it??
Sorry to hear that mate If you need a spare fuel ecu to test I have a spare 1 infact I have about 25
PMSL.
Originally Posted by philipeddowes
Originally Posted by James Raby
Anyway, going to test a different Fuel ECU and water temperature sensor
#42
Has no fuel supply to it and is also dis-connected
This morning did not present too much of a problem, this eveing was a bit worse but nothing as bad as it has been
#44
Getting a replacement Fuel ECU and water temp sensor tomorrow from a good friend (Phil Eddowes) and will see what difference this makes now LOL
Where's this valve mate?
#45
its the valve thats screwed to the underneath of the inlet manifold, it has 1 pipe going in to it and 1 coming out, it also has a black multi plug plugged into it. I think the valve should be open when its cold thus to aid starting but if it shagged it stays shut and so its harder to start and runs really shit until its warmed up.
Duncan
Duncan
#46
any luck yet mate , did you try the aux air valve ? If you take off the pipe going into it and try to blow down it when the engine is cold, if you can then its ok but if you cant blow down it that means the valve is shut when it shouldnt be !
Duncan
Duncan
#47
Duncan
Duncan
Anyway, tried a new Fuel ECU and started first turn of the key, just when you put foor on accelerator, stalls immediately
Been reliable informed this could well be the water temp sensor (I think) the sensor that is at the back and far left of the inlet manifold
i.e, thinking it's like -50 degree so chucking it loads of fuel and as soon as accelerator pressed floods engine and stalls??
I get a massive 'flop, flop' sound from the metering head when this happens
#50
Well, seems all is fine now
No problems with the car at all, may get a water temp sensor as it smells of fuel badly when starting up or idling when cold
Strange things never cease to amaze me
#51
glad you got it sorted mate, I've got very similair problems to what you had at the moment, I also will be trying a new fuel ecu tonight so I'll see if that makes any difference
Duncan
Duncan
andrewmctiernan
08-09-2015 03:05 PM
