Fuse box help.
Old 03-12-2008 | 01:12 AM
mk14dr's Avatar
mk14dr
Default Fuse box help.
Hi, Im having a problem finding the fuse box on a 2006 1.6 focus. I need to repalce the cigar lighter fuse, but unfortunately the drivers handbook was stolen when a window was put through earlier in the year so not only do I not know where the fusebox is, I won't know which fuse I need to replace (without taking out and inspecting each one).
Cheers in advance.
D
Old 03-12-2008 | 12:45 PM
RichieST's Avatar
RichieST
The fuse box is behind the glovebox. Open it, squeeze the sides in and it will drop down. You will also need to disconnect the damper if you have one fitted.
Not too sure on the fuse, but I can check for you when i get home if you don't know by then!
XR4
Ford XR Range
01-10-2015 01:46 PM
Steve Escos
01-10-2015 07:57 AM
muzzman1
30-09-2015 09:59 PM
deathrider666
28-09-2015 07:12 PM
Russ Payne
25-09-2015 09:29 PM
