s2 missfire on boost
Old Nov 29, 2008 | 05:36 PM
nickywarwick's Avatar
nickywarwick
Default s2 missfire on boost
my mate has an s2 with a collins chip, appariently they are suposed to run 15psi so is. when it comes on to boost it missfires & sound lyk its running on 3, its had new plugs/ leads/ dizzy cap & rotor arm, any ideas? origionaly thought it was fuel but am not to sure now.
Old Nov 29, 2008 | 05:37 PM
J1mbo's Avatar
J1mbo
B1mbo
correct plug gap ?
Old Nov 29, 2008 | 06:06 PM
nickywarwick
yeah, hes checked them mate.,
Old Nov 30, 2008 | 11:29 AM
nickywarwick
any more ideas? could it be the dizzy not advancing or retarding when on boost?
thanks nick
Old Nov 30, 2008 | 12:55 PM
Diamonds.'s Avatar
Diamonds.
injectors ok?
Old Nov 30, 2008 | 01:15 PM
Drag_steer's Avatar
Drag_steer
I will check ignition timing or fueling at boost.
Old Nov 30, 2008 | 01:49 PM
AJ-RST1's Avatar
AJ-RST1
The posh are up!!!
what leads to you have?
Old Nov 30, 2008 | 01:51 PM
ricky_2006's Avatar
ricky_2006
yeh i would check fuel mixture. play about with it when engine warm. u can use a screw driver.
maybe timing?
i would defo recomend it goes on the rollers and let the experts tune it for you
Old Nov 30, 2008 | 02:08 PM
spanner-86's Avatar
spanner-86
hi everyone its my car, ive just bought it with this fault gets to about 2000rpm and misfires(feels like the spark is blown owt), ive got new ford plugs leads dizzy and rotor, ive put a set of lifters and valve stem oil seals in and an oil and filter change, gapped the plugs 0.8mm. i took it to a small garage that could set the fuelling and ignition on it he got the ignition spot but when it came to fuelling the mixture screw would not adjust (threads stripped) but the co was 1.5% which he said would be okay just a tad ritch.
the second fault is their is a wire bridging the were the fuel pump relay goes bought a relay but it dont work there is no switched live so i was wondering were this live actually comes from is it the metering head or some pessure valve ?
Old Nov 30, 2008 | 03:17 PM
MK5RS2K's Avatar
MK5RS2K
on you come!
same happened to mine,turned out 2 be the ecu,u would put ur foot down and as soon as it hits boost it would start coughing and spluttering,think u might be needing another ecu mate hope this helps
Old Nov 30, 2008 | 06:55 PM
nickywarwick
lee got a spare ecu to try dan?
Old Dec 1, 2008 | 03:40 PM
spanner-86's Avatar
spanner-86
thats what it does i will try it he says he has one. cheers for the help m8
Old Dec 3, 2008 | 07:15 PM
BRAM's Avatar
BRAM
scrap it
Old Dec 3, 2008 | 08:06 PM
little bram's Avatar
little bram
got sum ecu's u can try bring them in to work tomorrow. where do u work again m8
Old Dec 5, 2008 | 03:48 PM
spanner-86's Avatar
spanner-86
haha, tried the ecu still no luck, but i have found a pipe were a vacum hose connects to on the pressure regulator but the vacum pipe is no were to be found and ideas anyone, or does anyone fancy sticking their heads under the bonnet for me its fastened to the metering unit on the left
Old Dec 5, 2008 | 03:51 PM
spanner-86's Avatar
spanner-86
or and nw its running a standard ecu and the boost down to 6psi and cheers little bram
Old Dec 5, 2008 | 07:34 PM
nickywarwick
can u not make abit pipe lyk dan?
haha lee your names mint.
Old Dec 5, 2008 | 09:59 PM
little bram
hey
Old Dec 6, 2008 | 03:33 PM
nickywarwick
arite lyk? got ya s2 running right yet lee?
Old Dec 6, 2008 | 03:42 PM
BRAM's Avatar
BRAM
Have you got it sorted yet then Danny boy ?
Old Dec 6, 2008 | 04:33 PM
spanner-86's Avatar
spanner-86
certainly havent big Ram ? lol, but my car wouldnt start today and i couldnt hear the fuel pump running so got underneath gave it a tap and away it went, so im goin to try a new fuel pump tomorrow.
nick, that pipe, i disconnected my boost gauge and stuck the vacum pipe on the regulator and it run lyk a ryt c**t so it either isnt supposed to be connected or it connects to something else ? sum one told me it goes to the actuator but it would have the same effect anyway :s
Old Dec 6, 2008 | 05:12 PM
little bram
did u not see josh the wash lik dan. u cud look at his car. il hav a look tomorrow c if i can find sum info or bits
(nick) the ecu's water temperature sensor was'nt working, me and stev's taking the engine back to bits. getin some new stuf now my cossies gone. was ok tho beat a subaru
Old Dec 7, 2008 | 02:04 PM
nickywarwick
lol. bit of a shame lyk mate was nice, u not go through insurance? whats the plans for engine now then? al have to have a pop over soon lyk aint seen you for a while.lol. got your garage built yet?
dan. so has your actuator got a pipe on? is that not the pipe thats suposed to be used for the fuel comp if there fitted?
get a new pump it wouldnt suprise me if thats what its been.
Old Dec 7, 2008 | 08:30 PM
little bram
no wasnt insurance m8 had it off the road, just put that t38 on and spend 800 on the head when the belt snaped dont no if i wud hav anyway and you no i never tell any1 what am doing. not be long nick and me and stev will buy it for cheap, telt him il giv him 500 for it lol
Old Dec 7, 2008 | 10:36 PM
little bram
think stev got it tuk away cos he nose it wudnt be long before i past him lol
we strating his soon
Old Dec 8, 2008 | 03:09 PM
BRAM's Avatar
BRAM
you would never pass me, lee boy
Old Dec 8, 2008 | 05:05 PM
spanner-86's Avatar
spanner-86
now now boys i went to see josh the wash lee and guess what . . . . . . His car is getting painted so i couldnt see it :S. wots that lee you will give me 2 grand for it ! As for beating the scooby wernt u getting towed by steve haha
Old Dec 8, 2008 | 08:47 PM
little bram
lol danny boy not bad. dont pay that much for scrap m8. Beat that scooby running my engine in, could'nt go past 3 lol, stev knows am going to kick has arse when i get it bk on the road. it only runs 2 bar boost
Old Dec 9, 2008 | 08:48 PM
spanner-86's Avatar
spanner-86
wel i tried that fuel pump with no luck, think am just p**sing in the wind now lyk lol, and i think your a bit ambitious lyk haha
Old Dec 10, 2008 | 11:23 AM
nickywarwick
sounds lyk you boys are having abit of competition for power. now ive never heard or seen that befor
ill pop over 1 day lee & you can tell me in secret wehat your doin then all help you wind dan up.
dan - how about phonin msd & gettin it booked in & get it sorted properly.
what yous doin t steves then? body work? engine or the lot?
Old Dec 10, 2008 | 05:20 PM
spanner-86's Avatar
spanner-86
ha !
Old Dec 11, 2008 | 03:26 PM
BRAM's Avatar
BRAM
Hopefully the lot nick want faster engine and cleaner car, but dont we all
Old Dec 11, 2008 | 04:15 PM
nickywarwick
very true mate, is body work rough lyk? or just a spruse up?
Old Dec 11, 2008 | 09:24 PM
BRAM's Avatar
BRAM
no its not to bad just a little spot of rust on the rear archs but going to paint the whole car. Are you not getting another rs like nick?
Old Dec 12, 2008 | 08:11 PM
spanner-86's Avatar
spanner-86
it will have to be 1000bhp to beat lees red rocket mind steve
Old Dec 12, 2008 | 08:19 PM
nickywarwick
yes & no mate. i realy want 1. but i fancy a focus rs, ill be looking after christmas for 1 realy only wana payt 8500 for 1 though, there going for 9 now. that or a s1.
Old Dec 12, 2008 | 08:36 PM
RS16iDale's Avatar
RS16iDale
do you still have standard boost pipes? because i had the same problem on my 16i turbo and it was the bottom boost hose (metering head to turbo) would collapse.
put a samco pipe on which was alot harder compared to the old soft ford pipe and it cured the problem.
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
