I need an 18" parallel from e39 bmw! With pics!
Any one know where there is ONE ? i wrecked one of mine and have been looking on ebay, all the ones available are the copies and i want a real m-tech one to suit the rest one the car. Its going on an E39 2001 530i sport so it needs to be the right one (apparently the hub sizes vary around these years? 70-71mm ???
Any help would be appreciated guys
These ones, the back ones are wider than the fronts and i need a front.
I had those fitted to my old 34 525i.
I hot a pothole & buckled one.
Ended up buying a set of reps for Ł360 from Fleabay as the cheapest
set i could find where Ł750 for 4 & they wouldnt split.
I was quoted Ł1700 for a genuine set from BMW.
Try Charing BMW Breakers in Kent 01233 - 713447
theres a set on edinburgh gumtree mate.think the guy wants to swap for a set of 17's but worth trying to see if he will sell them cheap?
http://edinburgh.gumtree.com/edinburgh/36/31209736.html
if you dont ask you dont get lol
St.
Just make sure the tyre size & profile is correct.
My wheel came with spigot rings & i had to use 40 profile tyres instead
of the 50 profile for the 7 to prevent scrubbing.
Heres an old pic of my Ł300 Ebay 525i Se with Ł80 750i wheels
7 Series rims fit fine on 5's bud (an 18'' wheel is an 18'' wheel at the end of the day).
Mine was also lowered so i had to change the profile.
A stock height 5 series should have no problems with a wider rear
with the correct profile tyre.
