Engine problems please help need ideas
Old Nov 20, 2008 | 10:28 AM
Rippers's Avatar
Rippers
Monte Geek
Default Engine problems please help need ideas
Basically my engine was dyno'd at Harveys, I fitted the engine, installed Fuel system Hayward and Scott made the exhaust and everything else has been fitted.
Its 8inj on greens, GT30 on T6 ECU.
I can start the car if I hold the throttle down and have to hold the throttle at around 3 thousand revs to keep it alive, let off the throttle and its dies. If I rev up it hesitates and misses. If I hold it for long enough to warm up it settles down and will idle but is still hesitant and misses when I rev it again.
So far I have tried new plugs, the Pectel Monitor shows no errors and neither does descpro when I connect the laptop to the ECU. The fuel pressure in the rail is 53psi with the vac hose off and 43/44psi with it on. The throttle body position is 3 degrees.
The engine was fine on the dyno and was mapped and ready to go, the only things different will be my Exhaust, wiring loom, fuel system and intercooler setup. So either somethings a miss or I've disturbed something on the engine.
Any ideas for me to try before I trailor it up to Harvey?
Old Nov 20, 2008 | 10:31 AM
Luca's Avatar
Luca
Lukesville
Must be a wiring issue mate, get it up to Harveys and checked over, before you start lashing out with the lump hammer.
DONT WORRY all will be simple
Old Nov 20, 2008 | 10:33 AM
Mike Rainbird's Avatar
Mike Rainbird
Caraholic
It WILL be the loom, something really silly that got missed or connected round the wrong way, as lots of the sensors require the correct polarity.
Old Nov 20, 2008 | 10:34 AM
Rippers's Avatar
Rippers
Monte Geek
I tried swapping the polarity on the crank sensor and that didn't sort it, and tried it without the cam sensor and it was the same again
Old Nov 20, 2008 | 10:37 AM
Lee_R21Turbo's Avatar
Lee_R21Turbo
You havent got the crank sensor & phase sensor plugged the wrong way round have you?
Old Nov 20, 2008 | 10:43 AM
rsnissan's Avatar
rsnissan
hows the TPS set up on a T6?
dont know much about them but I would have a look at that going on what you have said so far
Old Nov 20, 2008 | 10:44 AM
Rippers's Avatar
Rippers
Monte Geek
It shouldn't be any different from when it was set up on the dyno
Old Nov 20, 2008 | 10:46 AM
rsnissan's Avatar
rsnissan
i meant the wires/plug to the sensor.
Have you tried disconnecting anything to see if it will idle better? i.e TPS or ISCV
Old Nov 20, 2008 | 10:50 AM
Rippers's Avatar
Rippers
Monte Geek
I haven't tried no, I've got another ISCV to try aswell, that was the next thing, will try at lunch time
Old Nov 20, 2008 | 11:05 AM
ian sibbert's Avatar
ian sibbert
What's the map sensor reading on the monitor Paul?
Old Nov 20, 2008 | 11:06 AM
LHD220Turbo's Avatar
LHD220Turbo
is the CPS new?
Old Nov 20, 2008 | 11:08 AM
Rippers's Avatar
Rippers
Monte Geek
1.01bar then about .4 whne running, it goes up and down with revs. How ever it doesn't seem to be makin positive boost when reving up but its so missy and hesitant I may be wrong will check this
Old Nov 20, 2008 | 11:09 AM
Rippers's Avatar
Rippers
Monte Geek
Its a 1-36 YBP pulley using a YBP CPS bracket and what I thought was a YBP sensor but I was later told by Harvey it was a Zetec Sensor, it worked fine on the dyno and I have tried swapping the contacts on it
Micky The Finn's Avatar
Micky The Finn
Former Sponsor
is it earthed?
Old Nov 20, 2008 | 11:13 AM
Rippers's Avatar
Rippers
Monte Geek
Originally Posted by TF Rallyesport
is it earthed?
Actually no its not as I was told it didn't need to be by Fraser, he said that some Rally cars have them cable tied to the roll cages etc and are not earthed. I will try earthing it if you think it will make a difference also the same question for the coil pack does that need to be earth as again its not
Old Nov 20, 2008 | 11:36 AM
Micky The Finn
Former Sponsor
even if cable tied then they are still earthed.
fraser told me he was coming to fix my evo in mid august also.and he still hasnt shown up!!!
you need to get another mar sensor and earth it before you start it.the one you have now may be fooked.
Old Nov 20, 2008 | 11:37 AM
Rippers's Avatar
Rippers
Monte Geek
What about the coil pack?
Old Nov 20, 2008 | 12:16 PM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
Paul, what sensors are you using that wasn't used when it was dyno'd? Map sensor was my first thought (already mentioned)
Old Nov 20, 2008 | 12:23 PM
Martin-Hadland
is it earthed?
Do they need to be separately earthed, I reckon not.
Old Nov 20, 2008 | 12:24 PM
Coilpacks can go duff just like that, mine was working fine one day, missed a few times whilst driving, then ok again, next day wouldn't run clean until fully warm, changed to ACCEL 140018 coilpack, perfect ever since, even tried old one again, duff, so bin it was.
Did you actually SEE it running perfectly yourself ?
Tps may have been accidentally nudged a bit out, but go into TPS set up, then just a press of the accelerator and release and all is aligned again, you have the software on a laptop ?, worth checking this, as often overlooked.
Old Nov 20, 2008 | 12:40 PM
Micky The Finn
Former Sponsor
so why is there an earth on one of the bolt holes?
seen this about 20 times on rally cars that have had the sensor cable tied to the strut brace with no earth,missfire and behave exactly as paul describes above,change the sensor,add an earth and problem solved.
of course iam not saying that this is the problem here,just offering advice based 100% on experience of cosworths i have had over the past 18 years rallying them.maybe rally cars are different but boreham earthed all their map sensors on a seperate earth.
Old Nov 20, 2008 | 12:41 PM
Micky The Finn
Former Sponsor
and check the tps is saying 3 degrees +,as they will read - as well.
Old Nov 20, 2008 | 12:58 PM
Rippers's Avatar
Rippers
Monte Geek
I've only gone a sorted it.... I think
Get fucking in!
I wound the throttle cable back to 7 degrees open and all the symptoms have gone!!
Revs fine no hesitance or missing!
Must be I disturbed the TPS when I had the inlet powder coated so just got to reset it all and get it back to 3 degrees and working
Old Nov 20, 2008 | 01:15 PM
Mike Rainbird
Caraholic
D'oh!
And my loom suggestion wasn't a diss at Fraser, as I have even had one of my Pectel looms wired incorrecly for polarity on the TPS . There's so many wires that sometimes one can be done incorrectly .
Old Nov 20, 2008 | 01:30 PM
Martin-Hadland
Maybe shielding but it doesn't stop the operation of the sensor.
Old Nov 20, 2008 | 02:54 PM
Rippers's Avatar
Rippers
Monte Geek
Ok so now I have worked out the problem whats the proper way to reset the TPS, Cable and Idle screw?
I was going to get the car to idle at 950/1000 revs buy adjusting the cable and idle screw and then the move the TPS so its reads 3 degrees but I doubt thats the proper way to do it whats the correct procedure on this?
Old Nov 20, 2008 | 03:08 PM
As I said do you have the software on a laptop, if so, it should(if it has this feature) just be a auto calibration, through TPS/ECU config, although I have a different tps to a cossie on my cossie, it is but a 30 second job as above on my ecu, assume yours has a similar thing ?
Old Nov 20, 2008 | 03:15 PM
Rippers's Avatar
Rippers
Monte Geek
I have no idea actually would make sense if it did. How is it done manually thou?
Old Nov 20, 2008 | 03:43 PM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
You don't need to do it mechanically (other than ensuring you have full sweep).. you linearise the sensor inside DESC.
Old Nov 20, 2008 | 04:18 PM
Rippers's Avatar
Rippers
Monte Geek
I'm told NOT to touch the TPS via Descpro as it would upset the mapping done on the car, there is nothing wrong with the mapping its a mechaical upset that needs adjusting.. which has just been explained to me how to be done so wish me luck :Cry:
Old Nov 20, 2008 | 10:27 PM
polly_x's Avatar
polly_x
Paul, the way I would do it would be to have the throttle totally closed (leave cable off). Set the TPS to show 3 degrees in this position on Descpro. The reconnect the cable and check you get the full sweep. I think you will get approx 86/87 degrees max.
Then with the ISCV (not sure if your using the ISCV for idle or ALS?) disconnected, using the air bypass screw set you idle to around 1000/1100 RPM. Job done.
Give me a shout if you get stuck with descpro and and settings/features and I can pop over.
Stu
Old Nov 20, 2008 | 11:26 PM
Rippers's Avatar
Rippers
Monte Geek
Thats exactly how I was told to do it bar having the engine at normal running temps before adjusting the idle. Luckily I have a T6 pectel monitor with a remote screen that I can view the TPS position with Descpro
I'm told adjusting the TPS in situ is a job for Jeremy Beadle's hands thou
Old Nov 21, 2008 | 08:25 AM
On some systems(mine) it is just a press on the throttle then release, job done, mapping 100% spot on, as it calibrates itself.
Old Nov 21, 2008 | 08:45 AM
rsnissan's Avatar
rsnissan
Glad you ahve it sorted now, thought it might have been something to do with the TPS
Old Nov 21, 2008 | 04:03 PM
Rippers's Avatar
Rippers
Monte Geek
Ok interestingly I warmed the car up and let it idle. Wound off the throttle cable and took it off and the TPS was at 3 degree's so the sensor was ok after all. To make it idle I had to screw the idle pin in a lot. So all I could think of was the idle valve was stuck shut. I swapped it with a ISCV a mate lent me and adjusted the idle screw again and its mint and at 3 degree's I tested the ISCV I took off and it was working fine so I'm a little stumped now as to what was causing the problems.
The only think that slightly concerns me as to whether its normal or not is anything that uses power.. fans, lights heated screen etc makes the car idle much lower as low as 700 and when that low if you blip the throttle is has a very slight hesitancy to start with but revs straight through it.
Old Nov 21, 2008 | 04:08 PM
Mark Shead's Avatar
Mark Shead
Give it to your mapper as it was only done on the dyno, it is not uncommon to need to tweak these areas after putting in the car.
Mark
Old Nov 21, 2008 | 04:13 PM
dave cos4x4's Avatar
dave cos4x4
are you getting it fully checked over Paul now its all done.
whoever checks it can set the throttle etc....
Old Nov 21, 2008 | 04:14 PM
Mike Rainbird
Caraholic
T6 has closed loop idle speed control, and is one of the things that as Mark has said needs setting up in the final in-car mapping (along with cold start etc).
Old Nov 21, 2008 | 09:49 PM
Rippers's Avatar
Rippers
Monte Geek
Cool, its just due to recent events I'm a idle hypercondreact
It will go back to Harvey asap
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Ben26
Ford Focus Diesel
Aug 18, 2015 03:42 PM
JoeyBoyden
14
Aug 15, 2015 09:51 PM
taylora1409
Aug 12, 2015 12:06 PM
