Stack Dash Question ST700-SR
Old Nov 17, 2008 | 05:56 PM
James Porter's Avatar
James Porter
Default Stack Dash Question ST700-SR
Just wondered if someone could shed some light on this for me, Basically when i turn the clock on & click throu the settings i get: VOLTS,WATER TEMP,OIL PRESSURE,SPEEDO but i have a sensor in the charge pipe (Custom charge pipe) which i pressumed was ACT sensor, another in the top of the inlet where the small vacuum pipe to ECU/DUMP VALVE etc goes which i thought was boost? Both of these are the proper stack items & plug straight into it, But no settings on the actual display IF thats what them sensors are??
Thing is when i 1st got the car it did'nt run so i put a new engine in with a standard intercooler & charge pipe set up so the 2 sensors that go to the inlet & charge pipe did'nt fit!! If you get me drift!!! Im puzzled.....
Old Nov 17, 2008 | 06:31 PM
James Porter
Anyone please?
Old Nov 18, 2008 | 07:32 AM
James Porter
bump..
Old Nov 18, 2008 | 07:34 AM
pa_sjo's Avatar
pa_sjo
Colossal Pervert
What does it say in the manual? The chances are you have to configure the dash for whatever you've got hooked up to it. I just looked on the Stack website for you, but you have to register to obtain manuals so i'll leave that to you if you don't have one already.
Old Nov 18, 2008 | 07:40 AM
James Porter
Cheers mate i'll check it out
Mark RS
Oct 12, 2015 06:01 AM
M7 COS
Wheels and Tyres
Oct 1, 2015 04:46 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Fordmad!
Sep 29, 2015 07:03 PM
Mc5506
Sep 29, 2015 09:06 AM
