strut retaining nut...rounded
Old Nov 15, 2008 | 11:02 PM
baba's Avatar
baba
Default strut retaining nut...rounded
was removing front shock today and when i tried to slacken the Strut Retaining Nut the torx piece in middle of nut rounded...
got strut off car
any tips/ideas on how to remove?
Old Nov 15, 2008 | 11:08 PM
Lee_R21Turbo's Avatar
Lee_R21Turbo
Have you got the springs clamped yet?
Old Nov 15, 2008 | 11:35 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
If you have access to air tools, try an air gun or a battery inpact gun may work.
Failing that, depending on whether your replacing the shocks, try gripping the shock rod and undo the nut.
you could also just cut the nut off. best way if you can get one in there is a nut splitter. got me out the shit many a time and causes minimal damage to the thread!
Old Nov 16, 2008 | 12:27 PM
baba's Avatar
baba
yes the spring broke so got rest off.ok cheers guys.
Old Nov 17, 2008 | 03:37 PM
baba's Avatar
baba
managed to get the strut clamped in a vice today and got nut off.now i wont be able to grip it properly with new spring in place so if i didnt get it to bang on where it was before i was going to add loctite to nut.this should be ok i pressume?
Old Nov 17, 2008 | 05:45 PM
Rich_w's Avatar
Rich_w
Proven Legendary Status
Can I sugest you replace the strut? Given that the end is now damaged.
Old Nov 17, 2008 | 06:38 PM
n13los's Avatar
n13los
set of mole grips, if you have room.
Old Nov 17, 2008 | 07:50 PM
baba's Avatar
baba
i wouldnt say its totally fucked....its not that old and you can get a torx bit in to hold it but i just dont want to feck it altogether so id rather tighten it the last bit with grips or summit to be on safe side.
155lee
Oct 27, 2015 04:55 AM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
