Squealing brakes
Old Nov 15, 2008 | 10:35 AM
RichieST's Avatar
RichieST
Default Squealing brakes
Hi all
The rear discs on my focus squeal like buggery. I have tried removing the pads, cleaning them and the calipers up and refitting but it hasn't cured it. They seem to squeal under light braking pressure, but if you press the pedal harder it doesn't squeal. I have only owned the car a few months, and the pads and discs have plenty of meat on them.
Anyone have any idea of how i can cure it before it sends me mad?
Rich
Old Nov 15, 2008 | 10:44 AM
Twellsie's Avatar
Twellsie
have you put some copper grease on the back of the pads? also filing a slight shamfer on the leading edge can help
Old Nov 15, 2008 | 10:50 AM
pete mcrash's Avatar
pete mcrash
saff is working!!!...atm
as said above, bit of copper slip on the back of the pads..............
Old Nov 15, 2008 | 11:09 AM
RichieST's Avatar
RichieST
I did put a small bit of copper slip on, didn't help at all tho, maybe i didnt put enough on? I will try putting a chamfer on the front of the pads, see if it helps.
Thanks!
Old Nov 15, 2008 | 02:43 PM
Bee Tea's Avatar
Bee Tea
squeaky brakes are a common problem on the focus st170 like the flickering dash the girlfriend has just had her pads changed and they dont squeak anymore i'll find out who they are made by for ya but i would also suggest using some copper grease
Old Nov 15, 2008 | 04:27 PM
RichieST's Avatar
RichieST
Ok cheers mate i would appreciate it. The flckering dash can be cured by turning the brightness down a bit
muzzman1
Sep 30, 2015 08:59 PM
Sp3no
Sep 27, 2015 07:23 PM
