a good inlet/plenium to mod for zetec?
Old 12-11-2008, 11:54 PM
rst in breaking
rst in breaking's Avatar
Default a good inlet/plenium to mod for zetec?
what cars have a good plenium that can be chopped up to use on a zetec? cheers
Old 13-11-2008, 12:17 AM
Cozziekid
Cozziekid's Avatar
I've heard of people using a Rover inlet, not sure which one off hand though.
Old 13-11-2008, 12:22 AM
Cozziekid
Cozziekid's Avatar
http://cgi.ebay.co.uk/ROVER-COUPE-22...01149003r21676
Old 13-11-2008, 12:25 AM
rst in breaking
thats the one i had before lol, would a cossie one e any good? didn christian use to use a xr3i one?
Old 13-11-2008, 01:40 AM
Charlie Chalk
Unknown.
Charlie Chalk's Avatar
I can get one made for you..
Old 13-11-2008, 09:51 AM
rst in breaking
where from?
Old 13-11-2008, 05:40 PM
crazycage
crazycage's Avatar
how about one like this ????????????you can have it with any throttle body you want and what ever vac pipes you want .
Old 13-11-2008, 05:49 PM
Neil@FastFord
Neil@FastFord's Avatar
Are you on a budget?
If not, tons of decent options.
Planned power levels?
Area Six and stuff like the one above.
RS1800 or EFI inlet
If on a budget, the rover ones have seen decent results in the past. I have seen a Cossie one used. I'm trying to get one to fit on mine, but won't say until fitted and ideally tested
Could be a good thread this.
Keep the options coming chaps!
Old 13-11-2008, 07:25 PM
pa_sjo
Colossal Pervert
pa_sjo's Avatar
crazycage- I was contemplating doing a plenum like that on a Rover manifold (although slightly larger).. who did that one? Does it have trumpets inside?
Old 13-11-2008, 08:13 PM
crazycage
crazycage's Avatar
no trumpets but its nicely radiosed (spelling)and i made it .i
ps, if i made another one i would put all the vac pipes underneath.
Old 13-11-2008, 08:18 PM
rst in breaking
kind of on a budget atm as im not working but was thinking in poss using a cossie one. Do they have trumpets as standard?
crazy cage-ill bare it in mind mate cheers, ive got a mate who can weld so was looking for something that he can adapt for me, i.e changing flanges etc etc
Old 13-11-2008, 08:24 PM
Fudgey
Baby Cheesus
Fudgey's Avatar
the std zetec alloy inlet is good for 350bhp iirc.
so theres a cheap option that will fit lol
i have a cossie plenum cover you can have for the price of postage mate (that is just the cover, nothing else, all i got lol)
Old 13-11-2008, 08:37 PM
rst in breaking
thanks for the offer mate , it would have been the other half with the trumpets i would have been looking to mod lol, top fella all the same though .
The thing being with the standard inlet is i dont like the look of itlol
Old 27-11-2008, 07:49 PM
ShandzS1
ShandzS1's Avatar
Good thread! i`m looking into this aswel, cossie is an option or a custom one......
Old 12-12-2008, 08:53 PM
rst in breaking
anyone else got any other options? im trying to get the car back on the road like before with improved spec, would also like to see options for exhaust manifolds please? would like a gt30 flange too
Old 12-12-2008, 09:08 PM
Red16
Red16's Avatar
The standard rover manifold doesnt have trumpets inside the plenum.
Here's a few photo's of my mates rover manifold modified to fit a zetec, you can see how the 2 half's fit together, it might clear things up for those looking to modify one or it might not
Apart from the plenum, the manifold crazycage's manifold is a rover one.
Old 13-12-2008, 12:36 PM
crazycage
crazycage's Avatar
ive got a complete cossie inlet if your interested ??
Old 13-12-2008, 12:55 PM
rst in breaking
im brassic atm lol
Old 13-12-2008, 01:46 PM
Garage19
Garage19's Avatar
A cossie inlet will never fit a zetec. The port bore spacing on a YB is miles bigger than a zetec.
Old 13-12-2008, 01:53 PM
xr-stu
xr-stu's Avatar
i have a nissan pulsar GTiR manifold i was goign to fit to my fiesta. theyre awesome inlets, miles better than the rover ones. 42mm (iirc) throttle bodies for each port, radius's (i know :cry) cast into the plenum. very very good design. and the ports are only about 2mm off from the zetec head so very easily matched with a bit of work with a diegrinder and spacer plate. im sure folks whore more knowledgeable on pulsars will have more info on them, what power they can be used for etc.
ive still got mine with no use for it if youre interested mate.
Old 13-12-2008, 02:07 PM
rst in breaking
got any pics? and a gasket to show the port difference? cheers
Old 13-12-2008, 02:19 PM
xr-stu
xr-stu's Avatar
thats the only pic i have, shows a zetec gasket sat ontop of the gtir inlet.
Old 13-12-2008, 02:50 PM
rst in breaking
i think the ports are looking too far out for my liking, thanks though
Old 13-12-2008, 03:26 PM
xr-stu
xr-stu's Avatar
you recon?!
ok!
Old 13-12-2008, 03:40 PM
Charlie Chalk
Unknown.
Inlets are good for 450bhp too.
Old 13-12-2008, 03:41 PM
rst in breaking
you recon?!
ok!
im no expert by any means , but if its worked to match the ports then flow wont be even?
if someone who is knowedgable answer this it would be great, cheers
Old 13-12-2008, 03:44 PM
xr-stu
xr-stu's Avatar
yeah youre right but i cant see that offset made up over a distance making to much difference.
iirc they would need to be mounted at an angle. so would need a small manifold similar to you get when fitting carbs, with the mounting face for the inlet at around 45degrees to the head face. this would allow you to even up that offset without any trouble and match them both ends perfectly. thats what i intended on doing anyway. ive stripped the car and sold it all now though so as i say, no use to me.
rad, i thought they were good for even more than that but im no expert as i say!
Old 13-12-2008, 03:52 PM
puddy
puddy's Avatar
im brassic atm lol
How much bhp you after if you can't even go to a Ł50 inlet ?
puddy
Old 13-12-2008, 04:06 PM
rst in breaking
puddy
the engine is built, i meant i havnt got money to waste on experimenting due to being out of work for a while a little while back, then getting work, then company going under whilst owing me my wages, then crashing jims m3 and then i broke wrist so couldnt work but needs must so i went back after 3 weeks off with wrist in plaster (im self employed )
Old 13-12-2008, 04:08 PM
rst in breaking
and engine wise is a freshly built 2.1 zt with farndon steel rods, let pistons, new shells, mains, pumps etc and balance with arp stud and nut kit, felpro zt head gasket, area-six valve springs and cam with a gt30
Old 13-12-2008, 04:11 PM
Charlie Chalk
Unknown.
Butterflies are the restriction, not the ports.
Old 13-12-2008, 04:41 PM
puddy
puddy's Avatar
I am unemployed at the mo as well,and trying to finish a 500 bhp
cossie build as well
I will post a pic of my very modified 2wd inlet when I get it back
next week
Good luck,puddy
Old 07-01-2009, 07:44 PM
Vampire
Vampire's Avatar
think im gona go the fiesta turbo bottom part and custom top part for mine.
Old 07-01-2009, 08:31 PM
Lloyd
escort mk4 cossy 4x4
Lloyd's Avatar
i iam looking at using the st170 plastic manifold,with the injector set up.
cossy 4x4 inlet,with alloy tubes welded in,to connect to the st 170 connections.
all aligned to give a good flow angle into the cylinders.
Old 07-01-2009, 09:19 PM
rst in breaking
any pics loyd? i have a st170 inlet laying around lol. have you had it tested?
Old 07-01-2009, 09:41 PM
Lloyd
Lloyd's Avatar
no mate its all theory at the moment.
Old 07-01-2009, 09:43 PM
rst in breaking
you mean i have to wait for pics? lol, good luck
Old 07-01-2009, 09:46 PM
Rossco
Rossco's Avatar
I am using the Rover inlet as pictured by Red16.
Old 07-01-2009, 09:48 PM
rst in breaking
ive never seen one of them for sale tbh
Old 07-01-2009, 09:51 PM
Rossco
Rossco's Avatar
Yep they are pretty rare. I think it came from a 600 Turbo.
Quick Reply: a good inlet/plenium to mod for zetec?
