Spotlamp wiring?
Old 09-11-2008, 09:45 PM
fraser9764
fraser9764's Avatar
Default Spotlamp wiring?
Evening all, After a bit of advice on connecting up some spotlamps
Just mounted 4 7 inch lamps on the front of the 205 for the night stages of the RAC this coming weekend
(2 cibies and 2 hella rallye 1000's with 100w bulbs)
the bracket i've made is removable by 2 bolts so the wiring needs to be quick and easy to disconnect aswell,
i was thinking of using a 40 amp relay, 16WG cable straight off the switched junction box from the electrical cutoff, to a waterproof 2 pin connector mounted in the grille, and then daisy chaining the lamps together.
Does this sound acceptable?
And does anyone know of any suitable connectors? someone suggested using a standard 2 pin household connector, the kind that you would find on a lawn mower or hedge cutter? but this seems a bit cowboyish?
I'll post up a pic in a min of them mounted, looks hard as nails
Old 09-11-2008, 09:55 PM
fraser9764
fraser9764's Avatar
mark94
Ford Mondeo Including ST
10-10-2023 06:52 PM
01-11-2015 06:53 PM
Mark RS
12-10-2015 06:01 AM
cossie brad
29-09-2015 02:38 PM
IainRS1700T
25-09-2015 06:44 AM
Quick Reply: Spotlamp wiring?
