coworth hub carriers
30-10-2008, 06:55 PM
as above folks,
are escort and sapphire front hub carriers the same as XR 4x4 Sierra.
if not does anyone know what is the difference in them please.
30-10-2008, 07:40 PM
Super Moderator
Sapphire and Escort Cos are the same the XR4x4 range isnt
30-10-2008, 07:49 PM
Quote:
Originally Posted by
RS Specialist
cheers
would i be right in saying Xr4x4 has a different strut angle, resulting in a different amount of camber?
30-10-2008, 07:55 PM
the brake caliper mounting lugs on the xr are in a different place, I had to swop the hubs when putting cos 4x4 brakes on my track car..
steve
30-10-2008, 08:09 PM
Resident Wrestling Legend
the whole hub sits further in on the cossie than it does on the xr
if you ask someone who's got standard rims on to take a pic of their cossie and then compare it to the xr one youwill see how much further in they sit
30-10-2008, 09:24 PM
the youth
steve
Agreed, I had to change mine over when i fitted cos 4x4 brakes to my old XR.
30-10-2008, 09:51 PM
you can use 2wd four pots with xr4x4 hubs
30-10-2008, 11:41 PM
Are cossie 2wd hubs the same as a normal sierra 2wd hub?
31-10-2008, 08:27 AM
not quite, pinch bolts at the bottom and tapped holes for the brake lugs
the 3 door versions give you different handling but i'm not sure if that's to do with the rest of the suspension or not
mike r spoke about it as have several others in the past
31-10-2008, 08:34 AM
Super Moderator
lee2cossies
NO
31-10-2008, 11:41 AM
hubs
All im concerned about is the calliper fitting etc as iv got a spare pair of standard sierra 2wd hubs that i am using as templates to fit 330mm discs and brembo callipers.Are these dimensions the same?
31-10-2008, 02:11 PM
they measure up the same yes for brakes etc
it's only the hubs fittings on the lugs that differas they are bigger and about 1mm out for the cossie to normal hubs
Sierrasideways
08-10-2015 06:37 PM
stephenb4506
33
02-10-2015 06:25 PM
Adam-M
Was It You?
01-10-2015 07:55 PM
fordrallycar
30-09-2015 07:57 PM
jc1989rs
05-09-2015 08:09 PM
