Light Blues or Greys
Old 14-11-2004 | 01:52 PM
Demondave's Avatar
Demondave
Default Light Blues or Greys
What is the max flow rate for blues compared to greys. And is 400bhp on blues ok??
Dave
Old 14-11-2004 | 02:05 PM
wimwerf's Avatar
wimwerf
i dont know the max flow of l.blues but greys are 504cc. but with l.blues you can get 400bhp if its mapped properly. with greys its a lot easier.
Old 14-11-2004 | 02:11 PM
Demondave's Avatar
Demondave
So what is the max that the light blues will handel with out any lean???
Dave
Old 14-11-2004 | 02:20 PM
ECU Monitor Enthusiast
On standard fuel pressure (3.5 bar base)...
Light blues 400 bhp
Greys 430-440 bhp
Ultimately it will be down to the ecu map that makes the best of it for power
and/or economy. Not many mappers can make greys run economically !
(Stu can !)
Also, injector size is not just about BHP, the maximum rev limit of the engine
can effect what type of injector you use.
Old 14-11-2004 | 02:23 PM
Demondave's Avatar
Demondave
mmm I see.
And I take it that if I was using greys every day the fuel ecomey would be shocking (unless its mapped by stu! )
Dave
Old 14-11-2004 | 02:28 PM
Originally Posted by Demondave
mmm I see.
Dave
Tuners/mappers that pay attention to the whole map not just the top end power
delivery are few and far between !
Ultimately, who ever maps the car will decide what injector is required.
If you are just expecting to plug in an "off the shelf" chip for greys
then the chances are it WONT pass an MOT.
(From my experience)
I would always recomend a live map for ALL power upgrades no matter
how small or big the end power result is.
Old 14-11-2004 | 02:38 PM
jonseyrs's Avatar
jonseyrs
greys running to full potential wont pass an mot anyway
Old 14-11-2004 | 02:40 PM
Demondave's Avatar
Demondave
Ok cheers for the help guys. The car in question is running light blues at the mo with a t35 turbo, low comp, standard cams, polished and ported head, 500 cooler etc. Just wondering what the next stage would be for the car
Dave
Old 14-11-2004 | 02:45 PM
jonseyrs's Avatar
jonseyrs
8x dark greens 803's, waste of money going greys
Old 14-11-2004 | 02:49 PM
1000cc injectors (Good for at least 650 bhp) are ONLY Ł350 a set.. PLUS
a BIG Ally inlet manifold Ł300 ish .
ALL that cheaper and better than 8 greens/rs500 set up anyday ! (IMO)
Old 14-11-2004 | 02:50 PM
wimwerf's Avatar
wimwerf
8x greens is a waste of money.....better buy better injectors like the 750cc from Stu.
Old 14-11-2004 | 02:57 PM
jonseyrs's Avatar
jonseyrs
8x greens are good for round town also cos the way they are setup, unlike the other injectors which will only use alot more fuel when driving round town and not racing
Old 14-11-2004 | 03:00 PM
Demondave's Avatar
Demondave
So are these a direct fit/replacement for the blues??
Dave
Old 14-11-2004 | 03:01 PM
Demondave's Avatar
Demondave
And where would u be able to sorce that from from??
Dave
Old 14-11-2004 | 03:03 PM
Sorry mate, this IS a myth. Injectors provide fuel based on the map.
If the map has NOT been set up properly fully across the whole
working range (not just top end power) then this may be true.
I just dynoed a 632 BHP engine on 4x1000 cc injectors.
It ticks over smoothly and at idle and off boost the lambda is
around 0.98 to 1.03 (Very good in case you dont know)
This WILL pass an MOT test no problem.
Old 14-11-2004 | 03:04 PM
Dave
Speak to Mike Rainbird
Old 14-11-2004 | 03:05 PM
Demondave's Avatar
Demondave
So as above. I take it that the 1000cc injectors are not a direct replacement.
Sorry for the lack of knowldge here peeps.
Demondave's Avatar
Demondave
Cheers SECS
Old 14-11-2004 | 03:06 PM
wimwerf's Avatar
wimwerf
dont worry.
Old 14-11-2004 | 03:07 PM
jonseyrs's Avatar
jonseyrs
what mpg is that 632bhp engine around town then?
Old 14-11-2004 | 03:09 PM
Yes they go straight into the existing fuel rail/manifold BUT
you need a bigger inlet manifold back box for more than 450 bhp
Old 14-11-2004 | 03:11 PM
Demondave's Avatar
Demondave
But up to 450 they would be fine. So this would enable it to be done in 2 pahses get the injectors first. Untill a bigger turbo was sorced and then add the new manifold once done
Old 14-11-2004 | 03:12 PM
It should be not much worse than a standard cossie as this engine has
quite a high compression ratio.
The engine managment runs closed loop lambda fuelling control
upto about 8 psi boost.
Yes, it will use loads of fuel under high power outputs but that is obvious
as you need fuel to make power !
Old 14-11-2004 | 03:27 PM
Demondave's Avatar
Demondave
Old 14-11-2004 | 03:53 PM
Porkie's Avatar
Porkie
What a LOAD OF BOLLOX
I use 4x 1000cc injectors, make over 600bhp BUT off boost run closed loop lambda controlled fueling on my SECS Ecu for excellent fuel economy.
and as for your previous post about 'greys being a waste of money????'
WHY?!?!?!?!? 4 greys are great for 400bhp.. why go and over complicate things with 8 injectors when 4 will do the job?
Old 14-11-2004 | 03:54 PM
Porkie's Avatar
Porkie
oops, I see we have already covered all this!
Must read whole post first!
Old 14-11-2004 | 03:56 PM
Porkie's Avatar
Porkie
and yet more BOLLOX
On a roll!!!!!!
Dave, this is the inlet and injectors Simon is taking about.
Old 14-11-2004 | 03:58 PM
Demondave's Avatar
Demondave
Demondave's Avatar
Demondave
So basiclly its down to the mapper and they will be able to decide/inform me of the best rout eto take
Dave
Old 14-11-2004 | 04:01 PM
TIFF's Avatar
TIFF
Chasing Radders
There is some Classic one liners in this thread
"8x dark greens 803's, waste of money going greys"
"greys running to full potential wont pass an mot anyway"
Old 14-11-2004 | 04:05 PM
Porkie's Avatar
Porkie
Yes, very funny... BUT I actually find it quite annoying when someone puts up a post asking for advice and someone just talks out of their ass!!!
If you don't know, don't answer! or at least say something like 'not sure but I think....' or 'I am not an expert, but I think...'
Demondave's Avatar
Demondave
Now that manifold has got to be worth buying just for the looks alone
Wazzzer's Avatar
Wazzzer
that turbo's nearly the size of Martins head!
Old 14-11-2004 | 04:06 PM
Charlie Chalk's Avatar
Charlie Chalk
Unknown.
LOL @ tiff true tho
Old 14-11-2004 | 04:07 PM
Charlie Chalk
Unknown.
it is aint it
Porkie's Avatar
Porkie
There will be a few new engines coming out soon with much sexier inlets than that soon
Demondave's Avatar
Demondave
Thanks for the responce guys. Just working out which route to take
Old 14-11-2004 | 04:10 PM
TIFF's Avatar
TIFF
Chasing Radders
Dave
I had the same situation and i opted for Greys mate
Wazzzer's Avatar
Wazzzer
whatever you do you'll just sell it in a month
Old 14-11-2004 | 04:11 PM
SteveH's Avatar
SteveH
Surely EIGHT 803's plus the loom, inlet, throttle elbow etc etc would cost a shedload more than 4 big injectors, a large inlet back and a decent map??
PS: I want the engine in the pic porkie!!!
Quick Reply: Light Blues or Greys
