GT30 the new T34????
16-10-2008, 10:39 PM
Following cossie richies thread is the GT30 the new T34 for the cossie??would it be worth fir example putting a GT30 on a completely standard engine 205 or 200?i know richies was very close to standard!why are these turbos becoming prefered to the T34????
16-10-2008, 10:41 PM
Better spool, make more power!
16-10-2008, 10:43 PM
The cossie scene is finally moving into the next century!
16-10-2008, 10:49 PM
would that mean that the gt35 is the new t4 then???
so is there any gains on switching from a T34 to a GT30 on a standard engine with either block?
16-10-2008, 10:53 PM
Quote:
Originally Posted by
mechanic28
well yeah it has more horsepower potential, but you might not be able to take advantage of it.
i mean you can whack a GT35 on a standard 2WD cossie (i mean BOG standard, no changes no nothing) but if you wound it up to 400bhp something'd break
16-10-2008, 10:54 PM
Cake lover!
mechanic28
Theres the very small gain of about 100bhp.
16-10-2008, 10:57 PM
Jim Galbally
As long as you adressed the fuelling, i'm not sure it would break.
Nash
for how long on a standard engine
i presume the gt30 comes in alot smoother and is not as punchy as a T34?
Reason: tt
16-10-2008, 10:59 PM
Jim Galbally
Why would it providing it was mapped correctly with correctly specced injectors etc?? People have strapped T4s on standard engines & got 400bhp without things breaking!!
Doug beat me to it!!!
16-10-2008, 11:01 PM
std 2WD cossie?
std intercooler, std headgasket, std breather, etc. etc. etc.
how long you really think that'd last with a GT35 and 2bar shoved thru it
Cake lover!
Rich is the best person to ask i would imagine on the difference in feel between the 2 turbos.
16-10-2008, 11:03 PM
much better flow rate and spool up quicker due to using a roller bearing core
as doug said(garage 19) cossy's have joined the 21st century now with better mapping, cam sensors, siemens injectors and gt series turbos, its just evolution, and not before time,
but best thing about the gt's is external wastegates with screamer pipes, you got to hear a cossy with this set up to understand what i'm talking about
You would need no where near 2 bar to make 400 bhp.
I still think it would be fine.
The HG MIGHT give up after some mileage but that is easily solved. The rest of the engine internals can stay stock.
16-10-2008, 11:05 PM
i have a brand new coopers O ring on mine with standard head bolts (205)so the headgasket should be fine!
how many bloody dougs on here
16-10-2008, 11:07 PM
Cake lover!
Richs engine is not totally standard, this is what people have to remember.
Rebuilt engine, lowered CR and valve pockets in pistons, Grp A head gasket, BD14 inlet cam, Breather.
Its not like he stuck a GT30 on a 100k mile YB and hoped for the best.
I know and i can't remember the last time i met another doug in real life!
16-10-2008, 11:08 PM
i'm only running a t34 at the moment but thats due to finances, after xmas has been and gone i'll be looking at upgrading my turbo, either a t4 or a gt35, and if i can get it then it'll be the gt35 all day long
16-10-2008, 11:10 PM
i know somebody else called doug but he dont know cock all about cars so i cant see him coming on here lol
What were the physical engine differences between the RS500s & a standard 3Dr/Saph other than the 8 injectors, ECU, T4 & larger intercooler then??
16-10-2008, 11:13 PM
Sponsor
my next mod is ditching the t34 for a gt30
Lee_R21Turbo
different head,stronger block better inlet manifold etc
lee, the racecars didnt drive onto the circuit with a std RS500 enginebay
Sponsor
Lee_R21Turbo
none
16-10-2008, 11:14 PM
Nash
this is my point!is it worth going from a T34 to a GT on a standard lump in real terms?
16-10-2008, 11:15 PM
Garage19
well theres you,miller and me
16-10-2008, 11:17 PM
if you only wanting standard then stick with the t3, but as you've already got a t34 then standard isn't standard is it, just depends on how far you want to go realy,
btw did you get that noise fixed?
what was it? oil pump?
16-10-2008, 11:19 PM
westus1
aint looked at it still
just trying to inspire (sp) myself to fix it was thinking of the GT30 route
then up to stu for a switch over to L8 and live map
16-10-2008, 11:21 PM
Sponsor
16-10-2008, 11:22 PM
mechanic28
16-10-2008, 11:23 PM
rab's a doug too... get him in here :P
16-10-2008, 11:24 PM
it'll drive completely differant with gt30 and live map, i bet it picks up quicker and just feels more alive, defo go for it, nice little simple but very usable spec
16-10-2008, 11:25 PM
Jay.
me or doug or the other doug are you refering too???
i need to have a plan of action to inspire me to fix her
talking of which aint doug got a GT30 on his?
16-10-2008, 11:26 PM
Sponsor
shit this has turned out like the bob sketch from not the nine oclock news
16-10-2008, 11:27 PM
miller3
doug
aint you running a GT30?
cheers doug
16-10-2008, 11:30 PM
dougs got 1
16-10-2008, 11:31 PM
Yes mate
... Cant wait till full boost' but iv just spent all my dosh on a brand new shell
slight change of subject but to get the sump off can i just undo both top suspension mount nuts,will this drop down the front subframe enough to get the sump out?i am doing this on the floor with the car on stands
16-10-2008, 11:32 PM
Sponsor
just droping the crossmember will be fine ive done it before
miller3
Yes mate
cool!!your engine quite high spec tho aint it??does the GT 30 bolt straight in?use al lthe oie pipes etc just like a T34?
