Roger clarke power graph
Power at WHEELS.
Must be an ANIMAL with the gas going in such a light and well setup car, no wonder it wins so many things!
Interest comparison of with and without nitrous, just to show how much difference it makes to the whole rev range!
The power nearly TRIPLES on the gas just after 5000 rpm!
100bhp or so jets, giving 300bhp at the wheels extra due to the effect on turbo spooling.
Ban[B][/B]ned
Ban[B][/B]ned
but its down to charlie now to try and beat that time
the rcm subaru is an amazing car and sometimes looks like its got too much power for some tracks.
Chip, incredible graph!! what car is this in?
True but let's not forget the driver Olly Clark is an amazing driver and I do not know why he didn't go into motorsport with the talent he has. He's a great driver and he's also a very nice guy. I'd love a passenger ride in that car on track with him and I'd like to see it in a drag race off the line against an f1 car
Super Moderator
0 to 200 km/h: 3.9 seconds
0 to 300 km/h: 8.4 seconds, may be slightly more or less depending on the aerodynamic setup.
The acceleration figure is usually 1.4 g (14 m/s²) up to 200 km/h, which means the driver is pushed back in the seat with 1.4 times his bodyweight.
Andrew will be using his car this sunday for the final at the hill that he has already won then its game over charlie shaw has bought it.So andrew will now very soon be setting times in the woods.
50.0 is the time to beat at knockhill he might try weather depending on sunday to bring that down.
& the subaru will be faster with that power graph thats mental nice one the clark team
Happily retired
But surely its cheating Chip & most people dont like cheats .
I expect to see over 800atw (1000bhp fly) with mine on the Nitrous.
Given that the wasted spark fires so late when you are on boost (ie its at its most retarded point), its perfectly possible it could do so while the inlet valve is open, you will need to actually look at the point in the cycle you first see lift on the inlet cam, work out how many degrees of ignition timing that equates to, and then look on your map to see if that is an issue. (event then if you havent got perfect valve seal, it may still get enough fuel from the nitrous kit past to be a problem)
Can you not just go to a 4 coil setup to be sure?
Lead_foot, he ISNT joking, and its not a 50 quid plenum he is risking its an MIS one!
