help required re 3dr rad installation
putting in a pace rad and after looking underneath i note 3 holes in the rails the furthest back towards engine has the rad attached the next has a scoop and the next has the horns,in readyness for when i eventually get a 500 type cooler which holes does that use the middle or where the horn are?I see the horns need relocating in anycase so will do that but would be handy to know which holes the intercooler uses!
Football Cwazy
I thought as standard the rad was in the middle holes....then to fit a 500 type i/cooler you move it to the rear holes (nearest engine)
if yours is already there then it should be fine, just fit the i/cooler in the middle or front holes.
wowk
30-03-2021 07:49 PM
07-10-2015 12:56 PM
