how hard to change engine mounts on sierra?
whats the book time on em?
ie in a garage with proper tools, ramps etc. etc.
am thinkin about swapping mine for some pukka vibratechnics or something...
Originally Posted by Jim Galbally
do i really need "proper grpA mounts" in my ROAD car tho... it is my daily driver!
but ive got standard ones and the engine moves almost an inch when revving!
Edit to say maybe it's your dodgy shaped engine
don't know how the V6 is mounted, but on a normal cossie they are a peice of piss, just lift the engine up once you undone the nuts top and bottom of the mount and they come in an out dead easy 2 hrs at an absolute max
Originally Posted by Spiky
they probably just worn.
go get ford genuines one's and all will be
dunno about a thumper jim but easiest way to change them on a 3 door is to support the engine with a trolley jack and undo the hangers from the block cos you cannot lift the engine high enough to get over the engine mount top thread even with the bell housing pressed against the transmission tunnel, well i did manage it like but i have an engine crane at the time, only afterwards the remove hanger method was recommended
track.focus'd
12-08-2015 05:53 PM
