MK3 & MK4 Escort doors!?
If ur not worried about doors cards lining up r the doors on a mk3 escort the same as a mk4!? i.e. will mk3 doors fit mk4 car!?
also will mk4 mirrors fit mk3 door!?
Ryan what needs to be done then to make em fit!?
also when u ay whole dorr is different do u mena like the swage marks!? i.e. the door will look odd on amk4 shell!? & also will mirrors fit!?
Only major concern is the hole size for the lock which is larger on a mk4. So fitting a mk4 door to a mk3 needs some fiddling around if you want to use the original locks.
