Help Please!!!!!!
Old Oct 8, 2008 | 09:47 AM
Carmadlad's Avatar
Carmadlad
Ford Mad
Default Help Please!!!!!!
I need help with my RS TURBO lump please!
Old Oct 8, 2008 | 09:48 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
what's the problem with it ?
Physio's Avatar
Physio
Take two in the morning & two in the evening & see if that helps.
Old Oct 8, 2008 | 09:54 AM
Carmadlad's Avatar
Carmadlad
Ford Mad
Hello everyone, I wondered if someone could give me a little bit of advice.
I had 5 months ago a gorgeous Xr2i lowered spaced wheels the usual. Then I decided to drop an RS Turbo lump in it.
I've done all the nitty gritty stuff changed the whole lot wiring loom, ecu engine mounts engine (der!) gearbox new intercooler, new rad everything.
Guess what the bastard wont run properly and I have no idea what it is. It revs upto around 3,000rpm then wont go any higher. I can build up the revs to like 4,000rpm but if i put my foot down it just coughs and splutters.
I've rebuilt the head using my old XR2i top which only had 47,000miles on it, made sure its timed correctly but still it wont rev up....hmmmm?
Any ideas?
cheers
Old Oct 8, 2008 | 10:01 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
fuel pump ??
Old Oct 8, 2008 | 10:03 AM
lead_foot's Avatar
lead_foot
is awesome
More boost??
Old Oct 8, 2008 | 10:04 AM
Carmadlad's Avatar
Carmadlad
Ford Mad
Nah i dont think so thats the only thing I didnt change, you might know different but I got told the XR2i and RS Turbo ones arent far different from each other.
cheers
Old Oct 8, 2008 | 10:06 AM
Carmadlad's Avatar
Carmadlad
Ford Mad
Its not even boosting or getting on boost the turbo only kicks in at like 3,000rpm
Old Oct 8, 2008 | 10:47 AM
Carmadlad's Avatar
Carmadlad
Ford Mad
can anyone give me any info?
Old Oct 8, 2008 | 10:49 AM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Sounds like it's runnin outta fuel pal
Old Oct 8, 2008 | 12:06 PM
Paul_RS's Avatar
Paul_RS
Fuel or timing? My cossie did something similar a few months ago and it turned out to be a fucked fuel reg...
Old Oct 8, 2008 | 12:07 PM
lead_foot's Avatar
lead_foot
is awesome
Check your fuel pressure and get on Bosch 044 pump.
Old Oct 8, 2008 | 12:54 PM
Carmadlad's Avatar
Carmadlad
Ford Mad
ok cool, well ill try the fuel pump and/or reg but do any of you recon it could be the ecu???? cheers
Old Oct 8, 2008 | 01:39 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
Did you use the XR2i fuel rail & reg ??
I think the Fiesta's are in tank pumps arn't they ?? Change the fuel filter also for an rs turbo item.
jb
Old Oct 8, 2008 | 02:43 PM
Carmadlad's Avatar
Carmadlad
Ford Mad
r u sure that the filter would make all the difference?
Old Oct 8, 2008 | 02:47 PM
jb fletch's Avatar
jb fletch
MAD Carbon Cossie
No, not sayin that at all, but it won't help the situation !!
Main suspects will be the pump & fuel pressure regulator. Assuming your running the rs turbo injectors, ecu, map sensor etc ??
I'd defo say it's fuel related tho, going from your vague discription pal !!
jb
