New Track car for me... Should be a fun winter
There we go.... early 172 with throttle cable... 12mths test and some tax.. full history and some change from £1500.
Gonna give her a service, de cat, few bushes, set of harnesses, set of 888's and replace the gaylord rear lights then its Donno and Mallory Park here we come....
Cheers to Twellsie for driving me to get it and being quiet while I kicked the kid in the teeth....
Jake
Cheers Sideways- I know...
Kelv... I had a 182 and thought it was great but maybe a bit common and a bit expensive for what it was ( that was last year when they were 8-10k ) but awesome fun.
172's are the same more or less- reliable, shit build quality, go round corners like they aint there, stop on a penny.
Now you can pick early ropey ones up or find a diamond amongst the rough for the £2000-£2200 mark. I have seen em advertised at £1800 ish but thats mega mega miles and crap history/poor body work/cat D/C - in English FUCKED
This was advertised at £2200 and has the nicer (imo) 15inch wheels and as its cable throttle has less to go wrong (again imo). HPI Clear, Straigh as a dice, Cam belt changed with receipted for everything and full stamped up history- and goes like fuck.
Plus- at what I just paid its throw away money... in a round about way.
I've just driven it back from Lincoln in a "spirited" manor and it hasn't missed a beat and reminded me how ace they are- cant wait to stick it round a track.
If you have the spare cash for a bit of winter fun go for it- I cant see em getting much cheaper and for the money I've just spent I wouldn't dream of having a crock of shit old 205.
Also sod paying lots for one, no ones got any money and there are loads out there.
J
J
Almost there!
cheers for that Jake.
it was based on a budget of 2.5k if need be, and i do like what i see so far, several popping up around the 70k braket with FSH for about £2300.
ill bear in mind about the throttle cable aswell.
If you've got that much to spent you should get a minty mint one- depends how cheeky you want to be....
Lee...
Spoke to Dingy - should be doing Mallory and Donno next month- maybe get on Donno end of this month, def for the Christmas special and prob in Jan.
Spikey- I aint taking anything off it- second set of wheel + R888's and away I go.
Heres a daylight pic anyway
J
J
Looks same as my 172 track car i picked up for 2K, mine has some engine work though. Brilliant little track cars come over to www.cliosport.net for problems
Has yours got a Alloy bonnet of not ?
Almost there!
Jake, whats the main differences in the 172 and a 172 cup, or is that just me not noticing that they are all cups.
Looked at a W reg the other day but it hadnt been treated to the greatest of care in its life - so walked away.
but found a facelift model in blue now, 03 plate and is coming across very nice, but its a Cup model
Clio 172/182 differences/changes/facts on changes in production
Again please note where errors are Gweebs has volunterred to spell check and sort my grammer later on but factually it needs to be right first.
Clio 2.0 History
Phase 1 172
The first Mk2 2.0 liter cars were on a 2000 W plate there aren’t many though many were demonstration or car used as journalists test cars.
The Spec was as below
F4R 730 engine although there are some cars with a different code number (they are all the same power wise and there all F4R in the 172/182 range)
172 DIN HP (which is different than a UK HP, in UK HP it would be 166.6) throttle by wire cable engine
Sports body kit
ABS
Normal headlights (Zeons were never fitted even to foreign cars aftermarket kits are available though
They came in
Yellow (very rare)
Black (again quite rare)
Odyssey Blue
Mars red
Two shades of silver Titanian and icebear silver
No normal cars were ever made in green (see below),
Some cars have aluminium bonnet leading to the cars weight a few Kg's less.
Exclusive
At the end of the production run there was a special edition car made call the Exclusive there were only 172 made all sold in the Uk. The different features were as follows
Different alloys (multispoke)
Metallic green paint (this should be the giveaway since the normal cars never came in green)
Grey full leather interier.
Plaque in the car showing its number in the series. The rumours of extra cars having been made are false
Phase 2 172
The phase 2 cars first came out on a Y plate many were dealership or test cars on this plate though.
Differences were the use of the phase 2 body shell, interior etc also engine was changed to a drive by electric cable type (engine code F7R 732). Later versions of the engine used the turbo head casting which isn't as good but the engine code and power output officially didn't chnage. UCH computer to control all the cars electrics was also added and the gearbox was also changed. Reduced gearbox ratios were used to help keep the 0-60 speeds etc the same since the phase 2 172 weighted a fair bit more but had no more hp.
Also the front suspension was change different redesigned driveshafts etc were used but the spec is similar. (see here for the details of spec changes????????????????????????????????)
The CD changer was changed to an optional for £300 then added as stock spec then later removed again (when crusie became stock spec). In the phase 1 it was standard. Most people took this option up but if they didn't the CD changer cable won't be there if it is there then the last owner has taken the changer out but not the wire. However the wire is £86 from Renault and they are the only stockist.
About mid 2001 though the gearbox was changed the speedo sensor was removed and the speedo input comes from the ABS system. The ratios remained the same.
On about mid 2003 models ESP was added. On later cars a button apeeared to turn it off it appears on the drivers ride hand side near the traction control button. It can be switched off and if it is a little triangle appears on the dashboard with a car sliding about inside it. If its left switched on (it always defaults to being on) if it is operating then the triangular light with a picture of a car sliding about appears. Some people like the system others don't. For track work most people switch it off. Some switch it off all the time.
On later 2003 models also cruise control and speed limiter was added. Its easy to tell if a car has it as there the extra buttons on the steering wheel itself.
Also clear side repeaters were put into production about 2003. (from orange)
There were foreign special edition cars made notiable the PS2 version although I've no more information on spec so its unlikly to be any serious changes.
At about 53 plate a cost saving measure to remove the door locks was done. SInce the cars are French and legally you only need one lock on the doors they remove there passenger side door. In the Uk we had to live with the fact we drive on the other side of the road they weren't going to go make cars with locks missing on our drivers side.
The cars came in unique colours only seen on the RS Clios.
Flame red paint code B76
Monaco blue paint code 432 pearlescent
Iceburg silver paint code 640 metalic
Pearl black paint code 676 pearlescent
Options on it were
Sat nav
CD changer
Telephone preparation.
The wheel style is known as Alyum
Interier is known as Dark Grey Perforated Leather / Alcantara TC3
Cup
A special edition 172 was made called the Cup. It had nothing to do with homogenisation etc as many people think it did it was a cheaper version of the 172.
Item removed include
Xenons (normal lights were installed)
Climate control (Climate control was an option on later Cups but originally it was removed and most Cups don't have it)
Lumber adjustable leather seats were removed. Normal Cloth seats were installed instead
Front head rests were chnaged from the Coma style to fixed tilt ones.
Rear 60/40 split rear bench was removed instead a fixed one piece cloth was used. No rear headrests were installed and the middle full rear belt was used instead of the full spec normal one.
The aultomatic lights and wiper were also removed
The spare wwheel was removed and a can of tyre foam was instead used.
The front side windows and windscreen were thinned and ligthen the heat resistant and UV protection was removed??????????????????????????????. This does mean that they can crack easier and many people when there replaced have them replaced with normal ones as most garages don't realise the Cup had a different spec windscreen.
Engine cover was removed.
Some soundproofing was removed
The side airbags were removed in the seats
The ABS system was removed a brake pressure valve ensure the rear brakes don't skid brake the carr to hard resultting in a skid. This is often an MOT failure however the DVLA have issued a technical note (?????????????????????????????????) to make testers aware that the Cup is unique.
All Cups are missing the drivers side door lock (for info see above none in phase 2 info).
Ligthening knocked apparently 89kg but figures are unclear as real life seems to disagree.
A lower spec interior was used (known as Mossa Dark Cloth).
The plastic surround on the speedo dials is also in mondail blue unlike the normal 172 which is painted silver.
The wheels were changed for turini ones with a different offset (38.5 vs 48 for the normal phase 2 and 43 for the phase 1) The wheels are lighter than standard ones. Also fitted to the Cups were a different rear spoiler and front splitter.
The Cups suspension was also changed new strenghtened hubs were used since the wheels were of a bigger offset plus more camber was used Also spring and damper rates were reworked with harder lb springs being used . Toe in etc was changed but see here for more details.??????????????????????. The car should be 3 mm lower due to camber changes than a full fat but tolerances arn't that tight so 3mm has no effect. The track was widened due to the wider offset wheels and the adjustment of the camber on the car.
Early Cups only came only in mondial blue (code D43) later ones had the option of silver and air con was an option but finding a Cup with aircon or in silver isn't easy.
The Cups came with different auxiliary belts though the setup was much simplified and a new alternator.
Since the Cup doesn't have ABS the gearbox was changed to a JC5 130 gearbox this was only different in that it had a speedo sensor in it. This was used to give the car its speed signal. This is therefore a problem wwith the Cups that gearbox are more difficult to get hold of since normal 172 phase 2 boxes (whilst still fitting) don't have the speedo output so the speedo doenst work.
The Cup was sold in small number on the continent as the Raigngatti (famous French Renault racing driver) although they were all LHD and had a bit more weight removed as they had no rear windscreen wiper.
There were some Cups sold from a few dealers with a LAD tunning package fitted. This gave a claimed 200hp and warrently cover (where Renault cover was removed due to the modifications) for the modified parts.
Cups did come with some little badges on the drivers door they can fall of though and bought seperate from Renault dealers
182
In 2004 though (most 53 plate 182 is likely to be a demo car for a dealership) the 182 was produced. Changes weren't that large though.
New front suspension drive shafts hubs dampers springs were made
Rear suspension was changed
Leather seats spec was changed
The rear spare wheel well panel was deleted and replaced with a flat panel.
The new 182 exhausts with its V6 style rear pipes. The exhaust take up the space where the old wheel space was.
The intake manifold was chnaged it reputed to be better for moddification power but changes to it arn't huge.
The exhaust manifold is a 4-2-1 type designed. It can be made to fit a 172 but you need to make an exhaust cat to fit it.
The cat was also changed from a 400 cell to a 200 cell one. The exhaust is as mentioned earlier the V6 style one. Also the engine mapping was changed. The air filter was changed but thats more IMO down to cost than power demands.
Also changed was the gearbox for a longer ratio one (longer than the phase 1 original) also common failing week parts of the box ie the circlips were changed for stronger parts.
Options on the 182 included Cup suspension and splitter packs. The suspension pack lowered the car a few mm made the dampers, springs and shocks a bit harder also the wheels come in a darker colour. Included in the Cup suspension pack was different hubs which have 60mm hub bolt spacing they are also up rated as they run about 1 degree more camber vs none Cup packed cars. The spoiler pack put a bigger rear spoiler and a splitter on the lower front of the car. The front Splitter can sometimes be found missing as they have on occasion not been fitted from now or can damage due to there design. Most cars came fitted with the suspension and spoiler packs though.
Other options were
Paint colour choices were Blue (two shades of Blue were availiable, artic and racing ) , Black gold and Titanium
If you ordered you car in racing blue you could also have the competition strips added to the car.
6 CD Multi-changer (fitted under the passenger seat or if you had sat nav its fitted in the boot).
Sat nav (although this was removed from the options list due to lack of demand. If you did pick the sat nav then you couldn't have the Cup spoiler pack as the aerial caught against the rear spoiler. Some people did have it fitted though as whilst it catches and bends the aerial its not impossible.
ID paint this was an expensive option. You could have it in liquid yellow or petrol blue (there very few of the petrol blue ones though)
Recaro seat pack - Ambla/dinamica black front + Graphic charcoal rear seat (no leather on rear seats if you picked the Reacaro seats (this Recaro seats was only an option on later cars)
182 Cup
A few month a new version called the 182 Cup was made this was basically a 182 with both Cup packs but with the cheaper specification interior no Zeonons or Climate control (aircon instead).
Options on the Cup were
Blue paint
Inferno colour paint.
If blue paint was specified then you could have the competition strips added to the car.
Trophy
The last of the production models was the Trophy. It was produced using the 182 Cup body but the dampers were changed for Sach's remote dampers at the front and Sachs (none seperate reserviored) at the rear. Springs at the front were changed and suspension camber etc is changed. Also wheels were changed for turini style alloys
All trophys came as standard with the Recaro Seat package an the Clio V6 phase 2 rear spolier.
They also only came in there unique red colour. They have serial number on the drivers seat (only 500 were ever made there one prototype trophy what has been sold so arguable there 501 been sold. Also there's 50 swiss registered cars.).
Any more info please post.
march 2003 (03 plate). It had:
Clear side repeaters
Only one door lock
ESP with on/off switch
no cruise control
just to help clarify
Clio 2.0 History
Phase 1 172
Sports body kit
ABS
They came in
Yellow (very rare)
Odyssey Blue
Mars red
Exclusive
Phase 2 172
Options on it were
Sat nav
CD changer
Cup
182
Other options were
182 Cup
Blue paint
Trophy
Only one door lock
no cruise control
remember that scene from black adder with the sailor
"you have a womans car my lord"
who would have thought that.........a french car with shit build quality ROFLOL
Who would have thought it- a Sierra Cosworth owner who's car doesn't move and who's wife wants to sell it.
PMSL
Ph-1 clios are the best ones, basically having the cable throttle makes it better than the later ones.
In our house we have a Ph-1, a 172, and a 182. The extra track on my 182 is noticable against my brothers 172 (need to get a 182 with Cup packs for this though)
But if i was to buy another one now i think hand on heart i would just buy a PH-1.
Almost there!
Jake, i havent had luck to go and view the cup i mentioned, trying to achieve alot else this weekend and today.
the one Tabz has for sale appears nice and the mileage is a winner, unsure on the wheels tho
could just pop on a set of the Comp TH's via Matoon tho.
im still on the look out, but in reality the searching will have to continue after the weekend, unless something pops up on my doorstep
how yours anyhow? enjoying it still?
YEh its ace just got competition car insurance to insure it for £250 quid...
Gonna buy all the stuff I want this week and fit it all next week. Job done.
If you want me to go and have a butchers at Tabz car let me know- seems well priced... but I have to say a cash buyer is better going to find a desperate seller rather than a trader- traders wont take it in the teeth LOL.
Shings - who did you use for insurance then to get it that cheap!? I'm with A-plan and paid another £100 or so on top of that - although mine is the Ph2 on an 01 plate!?
open ya eyes ya blind dick
