Under Floor Heating
my sister has under floor in her conservatory,,, left it on over christmas last year so her cat would stay warm.... yes her cat..
had it up to 32 degres for a month or two
bill was around a grand lol
said she didnt think it would be expensive...... idiot
id only really use the electric one in a bathroom or sumthing under a tiled floor but if its for the whole house it would be better to get the water stuff.and would be much cheaper in long run.
Testing the future
is it of high electric consumption? well, you buy a kit based on how many Watts it consumes according to the room size. what you don't know is how often it will be on consuming that amount.
i will be fitting it in my bathroom. i know that i should have a qualified electrician wire it in, but i want to do all the prep work in advance. where would it be wired in to, as obviously you don't have a ring main in the bathroom? just tap in to the one in the room next door i presume (the upstairs circuit)?
Chasing Radders
If you run a wet system underfloor in say the bathroom.....and just come off the flow and returns from the heating system, it wont be that expensive to buy.........
My bro has it in all the rooms, even with a 5 bed place with two en suite b'rooms his bill is quite reasonable, think it's the wet system, thoughhis pad is one of these energy effecient places.
![Smile](https://passionford.com/forum/images/icons/icon7.gif)
ive been fitting rehau recently they seem to be ok done around 5 big schools in it.
its cheap to run as it runs alot lower temps than your radiators ive just put it in my dads conservatory off the main flow and return off the boiler as tiff says, i made my own recerculating valve fitted a 2 port valve, and stuck a separate pump and room stat on to it,
works a bloody treat and was alot cheaper than buying 1 off the branded manifolds
sit boo boo sit
![](https://passionford.com/forum/images/smilies/roi.gif)
Testing the future
yup mate feed it from upstairs socket circuit via an rcd spur if not fed from rcd in your distribution board already,put the control outside bathroom (seen em put inside!!!) and yes you do need a sparky that is part-p registered as it will be a notifiable job being in a bathroom
but ideally i would like the controller to be in the bathroom as well. we have a separate 'airing' cupboard where i would like to it to be, maybe half way up the wall so there is no danger of water reaching it in the event of flooding or whatever. there are no water pipes or anything in that area and it is in zone 3 or even technically another room as it is behind a door (no difference between that area and the landing really, they're both separated from the bathroom by one door
perhaps you would also be so kind as to advise me on the shaver socket. as that is low power, can it come from the lighting circuit, or should it also come from the upstairs socket circuit?
thanks
sit boo boo sit
thanks matey
whole house is on rcds from the distribution board, so that's easy.
thanks![Top](https://passionford.com/forum/images/smilies/smile011.gif)
thanks
to be honest ufh controls i install are fit and forget the only time i use it is to switch it off at start of summer and on at start of winter or to alter the time,as a result i put em out of the way but accessible
hope this helps
oh sorry for late reply was in pub last night....
daz
cossie09
10-09-2015 06:56 PM
