any help on centrel heating ..baxi solo 3 pfl 50
any help on this b4 i have to call a corgi guy out , i have a baxi solo 3 pfl 50 and all the light come on except the light for ..burner on..
so
boiler on
fan on
pilot on
burner off.. ?
the thing is i dont wont to get ripped off just dont trust corgi guys as they can say anything, no offence ment..lol
thanks andy
so
boiler on
fan on
pilot on
burner off.. ?
thanks andy
You got the gas turned on?
or
Pilot blocked,
or ignitor failed
or gas valve failed
or main burner flame detection failed.
or main PCB failed
Good news though the fans o.k.
or
Pilot blocked,
or ignitor failed
or gas valve failed
or main PCB failed
alrite mate just spoke to my dad and he said either pumps not running or you got a faulty gas valve or there mite not be enough pressure in the system if its pressurised
This boiler doesnt have a flow switch so the pump running or not wont effect start up.
Not sure if this boiler is sutiable for sealed systems either so the pressure this is out the window too.
If fan and pilot light are on but no main burner ist defo going thru igntion seq so is defo seeing demand.
Last thing on igntion is power to main solenoid and lights main burner.
An easy check is to remove solenoid and check resistance with multimeter.
Pilot neon just proves the burner sequence is trying the pilot.
are you running the heating from a thermostat/programmer? or timeclock which is on the boiler, try setting to override? as maybe kids have played about with it??
Dan
Dan
thanks for all the replies, as stated thers deff gas getting to it as you can see the flame from the pilot, ive put a new programmer on and made no diff so took it back to b&q , when i ask for heating nothing comes on ? when i ask for water everything comes on but the ..boiler on .. what does that tell anyone, and whats the best way to check the pumps runing, as it does sound very quiet but when i put my head to it you can here it
thanks
andy
thanks
andy
so how do I service a baxi solo 3pfl?
are there filters inside that need to be cleaned or something?
will I see when I take the front off?
or is it not d.i.y?
or is it not d.i.y?
Hi Morto,
just seen your comment "when i ask for heating nothing comes on ? when i ask for water everything comes on but the ..boiler on.. ............."
Regardless of what may be wrong with the boiler, this tells me you have an issue with the mixer valve.
I have a Drayton mid-position valve in my system, and when it got a little furred-up recently (hard water problem), it wouldn't go fully to the heating-only setting, and therefore didn't switch on the power to the boiler.
If you have such a valve, you can check if this is the problem by separating the electical body from the brasswork (simple operation). Then set your system to ask for heat-only.
If the boiler fires up, you will know that the valve is suffering from reduced movement, and needs replacing....... although I extracted some extended life from mine by giving it a good wiggle with an appropriate spanner.
Note though, that even when it's working fine there is only a very small arc of movement, so don't overdo the wiggling.
Ford Focus RS Parts for Sale.
09-03-2016 01:03 PM
cossie09
10-09-2015 06:56 PM
