Who's running Anti lag?
06-10-2008, 10:52 AM
Passionford Thread Killer
If your als stopped working and it meant you had a 5 and a half hour drive to get it fixed would you really bother??
My als was only active for a day before I encountered issues due to some of the parts I used
, and then once I replaced them I could'nt get it to work. Long story short I will have to make this long trip(hopfully it will get sorted in a day) to have the problem resovled.
Due to me only using it for a day I cant really remember if its worth it.
(I run mountune ISCV and TB)
06-10-2008, 10:58 AM
well if youv got it get it fixed.
06-10-2008, 11:04 AM
Virgin-popper
TBH I wouldn't bother. Fix it before next season
How indecisive are you!? It's your car, if you want it do it, if you don't, don't!
Just tell me its not Engine Advantages you need to take it back to!
06-10-2008, 11:05 AM
Quote:
Originally Posted by
R5FORD
Thats what Im saying ,would you drive an 11-12hr round trip spend Ł100-130 on fuel and then however much labour cost come out at to hopefully get it sorted in a day? (but may not and might have to stay in a hotel)
06-10-2008, 11:06 AM
ballin
Read what I just wrote, hows that indecisive?
No not EA
06-10-2008, 11:09 AM
Why do you need to drive so far?
Surely someone closer can help you?
06-10-2008, 11:11 AM
Coldo
Nope, done all I can down here
06-10-2008, 11:13 AM
Hows it gone wrong if you don't mind me asking?
06-10-2008, 11:17 AM
Paul,
it don't work.lol
It just doesnt activate.
06-10-2008, 11:30 AM
well go for it fella get it fixed. youl have to do the journey sooner or later.
06-10-2008, 11:52 AM
Monte Geek
Have you tried when the car is hot ie water temp on 70 degree's as some don't come on untill then anyway and tbh unless the car is hot anyway it will be shit.
Have you tried cleaning and oiling the Mountune top hat as this is usually the problem as they are prone to stick and not open
06-10-2008, 12:00 PM
PassionFords Creator
Most common causes are:
TPS not going to zero properly, or reads unstable.
ISCV Faulty
ALS wire not grounding cleanly.
ACT or ACT tempo out of range.
06-10-2008, 12:04 PM
I dont see the appeal for Anti Lag on a road car??
06-10-2008, 12:05 PM
Super Moderator
tps is the most common problem I see ,min throttle position incorrectly set
06-10-2008, 05:51 PM
Never tried the act, I'll give that a go.
cheers stu.
06-10-2008, 06:02 PM
Carbon Crazy
SapphyMike
Some road cars go on track days and "private roads" where it might prove useful/fun.
07-10-2008, 05:42 AM
I think a lot just like the noise.
07-10-2008, 07:50 AM
Post Miester !
I agree... how much was it again..
07-10-2008, 08:06 AM
on my car i actually needed to have the headlights on before it worked...
never figured out why....
Also after flipping the switch i needed to give full throttle to activate it.
07-10-2008, 08:33 AM
warrenpenalver
As he said , track days.
07-10-2008, 08:57 AM
loader5710
Black flag time for excessive noise
07-10-2008, 09:17 AM
NUTS RuS
Indeed, not many of them will let you get away with it.
Though heard some ppl using it at combe.
Would be good if I could get it sorted for Landow(sp?), so small and tight there.
rex647
06-03-2022 06:20 AM
Kam B
24-09-2015 10:40 AM
tib2220
14-09-2015 12:33 PM
Eigdoog
13-09-2015 05:46 AM
ajamesc
08-09-2015 06:51 PM
