arb/compresion struts
here you go lads this is one of the best pics
heres a link to my photobucket look through and you'll find more pic which could help
http://s254.photobucket.com/albums/hh112/jimg518/comp/
do the comp struts mount to the original holes for the anti roll bar? if you were to remove the anti roll bar and just use the comp struts what advantages/disadvanteges would their be?
Compression struts also give you a level of adjustment to alter the position of the whel in the arch - back and forth (which i believe is castor!?)
thicker ARB in comparism to what alternative?
jimbo, the esc cos front arb is the thickest fitted to cosworths.
not sure what size the granny cosworth was tho.
so don't know what thicker one he could fit..
steve
steve
ps ive got AVO monotube coilovers that seem to have the stiffest springs in the world, so im quite sure ill be ok with no arb. its not a car that i will be going on holiday in, so ride comfort isnt on the top of the list lol
[quote=Kelv;3635108]Personally i wouldnt sacrifice my ARB for compression struts, either spend a bit more and go for the type of kit that allows you to utilise both or stick with the ARB!!
so just get adjustable tca's and keep my arb? i want what will be best for track not bothered about road use really
Would it be possible to use compression struts and still run the standard antirollbar ? I was thinking an extra bracket welded onto the comp strut mount then a clamp set up similar to what RS1600i use.
