Level 6 Pin 21?????
strange as my level 6 has a wire attached internally to it which then is soldered onto a pin on the chip which is not plugged in to then have a resistor going onto the next pin!!!???
Someone has modified that to enable a map switch function.
They have fitted an eprom that is twice the size, and loaded 2 chip programs in it.
The extra pin switches between 2 seperate programs in effect.
Multiple ignition maps most likely!
Ground the pin to switch chips.
Gareth,
Actually that eprom is 4 times the size of the standard L1 chip.
The ecu can only read the size of its original chip unless its been modified with a plug in board etc....
L1 used a 2764 (8 kb)
L6 used a 27128 (16 kb)
L8 used a 27128 (16 kb)
P8 used a 27256 (32 kb)
You can use bigger as long as the extra address pins are fixed in a known state.
Effectively, half that chip is empty !!!
i remember stu talking about this to my years ago! saying 27c128 are getting hard to get hold of, so maybe using 27c256 in L8's
i didnt know L1's was 8kb's PMSL
Yes, its much cheaper to use a bigger/faster memory chip now !
How times have changed...lol
When I first started in electronics my first eprom I ever used was a 2708.
It had 512 bytes (half a kilobyte) and needed 3 voltages +5v, +12v and -5v and consumed around 20 watts of energy LOL
Trotter,
Yes I am 100% sure this is what that does. I do have ECU experience
As for what is in the chip(s), ONLY the original tuner will know !!!!!!
Could be different maps for anything, ignition, fuel boost and/or any of those !!
so just getting a level 6 ecu will plug straight in with no other mods?Not interested in L8 and all those stupid gimmicks just want a chip to run greys and a T34
PassionFords Creator
Gareth,
L6 used a 2764 (8 kb)
muz
30-09-2015 08:29 AM
