cossie calipers-2wd or 4wd which are best?
im wondering whats the best set up to go on a rst, with the issue being 4wd are single pot but larger piston and compared to the 4 pots? and why would ford change them to single pots? cheers
just finding my feet
the 4x4 saphs where made to a smaller budget unlike the 2wd's hence most stuff for 2wd is practically bespoke and the 4x4 is a bitsa
saying that the 2wd calipers are transit 4 pots with spacers to allow for wider brake discs anyway
orion=mini saff
as brakes,there a good cheap upgrade,they work superb on a escort/orion,like u say,i only got ur alfa ones as thery look nicer behind the wheel!!but they dont look tht bad
actually, the 4x4 pistons are like bin lids and work very well.
I'm sure in back to back tests there is no difference in performace between the 2
how many 2wd owners can honestly say that all 8 of there pistons are actually working, 20 years of use will have fooked them up..
at least 4x4 owners only have 2 pistons to worry about lol
steve
steve
steve
steve
marketing is one thing but reality is another
Homologation means using original parts, ford are not going to say these later 4wd calipers are crap when that is thier current car for sale at the time are they ?
Can anyone honestly say they have ever seen a set of pads in a single pistons sliding caliper wear perfectly matched either side of the disc, so a lot of the force goes in binding of the slider mechanism, and four pots equal more consistent pad pressure so not developing hot areas unlike a single piston one just pressing in the middle, they also have more mass to dissipate the heat.
Resident Wrestling Legend
the 4wd cars had single sliding calipers
the 2wd cars had fixed 4 pot calipers
it's generally agreed that the 4 pots will spread the load across a greater area more evenly than a single pot sliding version
where has the second pot come into the equation then?
besdies, if you want cheap effective stoppers, mondeo mk3's had 300mm discs and single pots and if it's enough to work on something like the st220, it'll be more than enough to work on the little escort mate
you have the same pressure being applied so i would have thought there was no actual difference in pressure on the pads, the only difference being in the area it was alliped
the 2wd caliper having a more even spread whereas the 4wd caliper would apply it on a leading/trailing side of the disc
not that i want to start a row or anything i just want to know as if there is a recognised mechanical principle invovled here that is not common knowledge it would be good to have the info out there
although i'm not sure what it would do to sales of multi piston calipers
yeah thats always the way, but working one work very well.
mine on the nurburgring proved that, although after 1 lap they were a little spongey
but that was down to fulid and lines.
as i see it, if you pres the pedal with force X the fluid in the lines will see force X and the caliper will see force X
but on the 2wd version, force X is applied to 2 parts of the pad (top and bottom) on both sides so you get (essentially) an equal distribution of pressure across both sides of the pad and onto both sides of the disc
with the 4wd setup you have force X pushed onto the inside pad first, this in turn pushes against the inside face of the disc, which pushes against the sliders, which then pull the other side of the caliper towards the other face of the disc, pulling the outer pad in towards the outer face of the disc
much more losses and uneven pad wear as the inner pad will, invariably, wear out quicker as it's in more use
the only positive side is that you have the full force of X hitting the inner pad first and, as the piston is going to require less fluid to push it out, it "should" give you a better feel through the pedal
in the real world i felt that multi piston calipers gave an easier "on the limits" feeling through the pedal as to when they were about to lock up or not
unless of course we are only talking about the cosowrth 2/vs 4wd set ups, in which case, the 4wd setup might win on the bais of unsprung weight
Black Country RSOC
I ran both set ups, ie 2wd 4 pot calipers, 285mm dics, and 4wd single pot caliper and 285mm disc on my old 247bhp S2 trackcar.
in respect of stopping power, both were equally as good. HOWEVER, the 4wd calipers used to warp discs like no tomorrow. Probably caused by the unequal pressure on each side of the disc?
Got through god knows how many discs and pads it was shocking. Fcuked the lot off in the end and got BG developments to build me a AP racing 4 pot brake kit.
best mod i ever did!
