saff aerial lead where it go??
Getting some paint work done on the saff and i am removeing an aerial some ones fitted on the rear wing
someone has cut the aerial lead to fit the shoonky aerial on the back wing.
Now it`s not long enough to go to radio amp on the rear parcel shelf got a new aerial lead(from radio to amp back window) where does it run under the carpet or in the roof lineing?
Testing the future
roof lining is not that difficult to remove and get back properly, particularly just on one side. the fabric is glued to a card panel and you just remove the door seal and the a,b and c pillar trims and maybe the sunroof rubber, and the jesus handles and the sun visor.
wouldn't do it if your car is mint and you want to keep it that way though
up the apillar and inbetween pillars and roof skin the down c pillar and to the rear windscreen
i replaced mine when i reshelled
easy to remove not so easy to get back in as it goes inside pannels were you cant get to
The Youth.
30-09-2015 09:59 PM
