harvey gibbs engines??
#41
Its the same of all reputable tuners, If you pay to have it doen properly, it will last !
Most people DIY a chip, run more boost then complain its blown up.
Tuners like Harvey, provide a package thats tried and tested.
#43
Between andrew ,chris doc,charlie,ian donaldsons old car (silver escort)now stewart whyte's car i have seen about 8-10 different engines from harvey & they have all been great.They have had probs but the abuse they have taken is unreal for the power they put out.Charlies old focus was at crail as well with a 380 harvey engine & it done a 12,2 not bad ehh im sure there was a bit more to come once the lad gets used to it..
What i like is i have seen it at andrews the engine comes all mapped ect ready to bolt in wire up & go chralies old 440 engine has took about 6 years of solid abuse every time its been started.
#44
#45
i must admit i am thinking of swapping my greys for siemens and getting stu to map my harvey engine as I am not all that impressed with the Ahmad map.
Cant fault the engine though
#46
plenty of other reliable powerful cosies been built over the years by other tuners
#47
#49
#50
and expensive and to be honest i don't have a clue from such things so i don't understand what the benefit of a T6 is (i'am sure it is faster, have more memory and it can read out things like rpm from the turbocharger) but is that useful for a road car?
#51
t6 can do sooo many features its a bit over the top for road use really unless you want 8injector anti lag data logging ect ect
#52
not that impressed with the map off boost (very rich) on boost is fine and also more can be got out of the engine with bigger injectors but he wont map bigger than greys, have to go to 8 injector set up - mau still go that route to be fair we'll see
#55
Considering they're mapped on the dyno at stoich (on part throttle), it can only be the installation in your car that is causing the problems.
#56
ooh good question!
well you dont get 12 position boost pot for sure im not sure if you get a adjustable boost control acctually ! thats another advantage of t6 eh !!
#58
worth of waiting a month longer only for a ECU? not sure...
a little bit off topic but what is the next stage after the t38? T4 with ........
..........erm T6? serious question as i don't know really wich way to go.
think i have to come over to do a few (passenger) test drives.
anybody?
#59
does this look ok for ticking over??
[IMG][/IMG]
#60
thx for the info so for example it could run 30psi of "standart" bosst and (with the switch enabled) 10psi(thats enough for the gf)?
#62
#63
but at some point my escos should be back on the road
anybody?
anybody?
#64
#65
if he just wants to have it checked ie put monitor on it then if harvey was closer then it would be logical to see harvey for a quick check but if he wants it checking and the map modifiying then obviously take it to ahmed
#66
#67
If you look at the guys location you can see that Harvey isn't closer.
#69
i think he will be the man who will build my engine due i heard only good things from him, i was very pleased with an engine he build for a friend of me (TurboGuido of here) AND HE WAS THE ONLY TUNER/ENGINE BUILDER FROM THIS BOARD WHO TAKES SOME TIME TO ANSWER MY MAILS (i cannot phone to anyone due my spoken language is much more worse than my written one)
#70
engine was put in, went up road with wideband = rich
took it to ahmad about 2 days later to check it = still rich
so I assumed this is just how he mapped it.
all happend in a matter of days as i was limited for time before Lemans.
its all perfectly safe is the main thing, like i said just wondered if the part throttle/off boost could be mapped better.
Not taking anything away from Ahmads mapping skills (I did half expect it to be quite rich from what i had heard/seen before so I wasnt surprised)
#71
well i know its hard to have a convo but im sure he'll be able to understand/help if you ever did want to ring ! if not just email and like ya say he'll get back to you
#72
But sure, you've done your own tests which is fair enough. I personally would go back and have a chat with him about it before going elsewhere.
#73
He maps road engines at stoich on part throttle, so not quite sure what's going on with yours. A lot of bollocks is said about his calibrations, one week everyone says they're 'lean', the next week everyone says they're 'rich'. It's a fashion-of-the-month thing.
#74
col why waste your time going to harvey when if you gave Alan less cash he could get same power?
Harveys engine seem to make good power and last a long time but they aint the be all and end all.
#75
I'm sure Andy G and co get a good deal off Harvey for all the bits they have but if Alan was that much better I'm sure they would use him as he is so much closer.
Can't deny he done a good job of yours though
#76
Had my engine for 6 years and still going strong! Other than a headgasket going (Which was no fault) it still goes and pulls like a train! Top bloke
If a tad lanky LOL
If a tad lanky LOL
#77
#78
Simple answer would be time
Im more than happy with my ava engine but the quick turnaround and ready to fit style of Harveys engines is a big bonus.
#79
Im not saying Alan is better but Im sure he would be cheaper.
#80
