Benefits of running a low compression engine ?
as above really, what are the benefits of running a low compression engine in a s2 erst as apposed to a standard compression one ?
cheers, Duncan
cheers, Duncan
drawback - less off boost drivability
Any other benefits apart from being able to run more boost such as less chance of det etc....
Duncan
Yep, you can run more boost & ignition advance before the onset of det.
As far as the off boost driveability goes, if it's all set-up well there aint THAT much difference but I suppose that would depend on how low you went.
ekjim
17-08-2015 08:57 PM
155lee
14-08-2015 11:21 AM
Zoggon
10-08-2015 10:39 AM
advantage, advantages, benefit, benefits, benefitsof, car, compression, cummins, engine, engines, low, lowering, petrol, piston, running
